[Discontinued] Arducam MT9V022 0.36MP Global Shutter USB Camera Evaluation Kit - 1/3-Inch Monochrome Camera Module with USB2 Camera Shield
[Discontinued] Arducam 8MP Synchronized Stereo Camera Bundle Kit for Raspberry Pi With Fisheye Lens Pivariety
[Discontinued] Arducam 3MP WDR USB Camera Board with M12 Lens, Dual Microphones 1/3" AR0331 CMOS Senor USB Audio Webcam Module for Computer, Laptop, Android Device, and Raspberry Pi
UB0237
Discontinued, check alternative item B0438
  • Ultra HD Resolution and WDR: 3 Megapixel 1080P USB camera with dual microphone, ultra HD 1/3” AR0331 sensor, max resolution is 2048 x 1536@15fps, dynamic range up to 110DB, which can provide sharp image and accurate color reproduction.
  • High-Quality Imaging: High-quality 70-degree horizontal view angle M12 lens with IR filter, which provides decent image quality. MJPG 30fps@1080P/720P/1280 x 1024/640 x 480/320 x 240; YUY2 30fps@640 x 480/320 x 240; H264 30fps@1080P/720P/1280 x 1024/640 x 480/320 x 240.
  • Capture Video with Audio: Dual Microphones for high-quality digital MIC (optional dual/single channel). MJPEG/YUY2/H.264 compression format optional. Contrast/Saturation/White Balance/Exposure/Acutance parameters are adjustable.That all means that you can get a colorful and vivid video.
  • Plug&Play: UVC-compliant, just connect the camera to a PC computer, laptop, Android device, or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Applications: This mini-size camera board (38x38mm) highly recommended for the video surveillance system, live streaming, videoconference, dashcam, and other video vision applications that need high frame rates with high resolution.
$64.99
Arducam UB0237 is a 3MP, based on the 1/3" AR0331 image sensor, UVC compliant, HDR USB 2.0 camera.
SPECS
- Sensor: 1/3” AR0331
- Resolution: 2052(H)x1536(V)
-Frame Rate: MJPG 15fps@2048 x 1536; 30fps@1080P/720P/1280 x 1024/640 x 480/320 x 240; YUY2 5fps@1080P/1280 x 1024; 10fps@1280 x 720; 30fps@640 x 480/320 x 240; H264 30fps@1080P/720P/1280 x 1024/640 x 480/320 x 240.
-Field of View (FOV): 70°(H)
-Lens Mount: M12
-IR Sensitivity: Integral 650 IR filter, only visible light
-Focusing Range: 3.3ft (1M) to infinity
-EFL: 6.0mm
-Adjustable parameter: Saturation, Contrast, Acutance, White balance, Exposure.
-System Compatibility: Windows XP (SP2, SP3)/Vista/7/8/10, Linux, and Mac with UVC
Power
-Power supply: USB powered 5V
-Working Current: MAX 300mA
Physical
-Operating Temp: -4°F~158°F (-20°C~+70°C).
-Dimension: 38mmx38mm
-Hole Pitch: 34mmx34mm, 28mmx28mm
-Cable Length: 3.3ft (1M).
