[Discontinued] 5MP Wide Angle USB Camera with Mini Metal Case, 1/4
[Discontinued] 5MP Wide Angle USB Camera with Mini Metal Case, 1/4" CMOS OV5648 Mini UVC USB2.0 Video Webcam Without Microphone for Windows, Linux, Android, and Mac OS-Arducam
[Discontinued] Manual Focus Lens USB Camera with 1/2.8
[Discontinued] Manual Focus Lens USB Camera with 1/2.8" IMX291 Image Sensor, Low Illumination Webcam with 4mm CCTV Video Lens for Android, Linux, Windows-Arducam
[Discontinued] 1080P Low Light Low Distortion USB Camera Module with Mini Metal Case, 2MP CMOS IMX323 Mini UVC USB2.0 Webcam Board with Microphones, 3.3ft/1m Cable for Windows, Linux, Android, and Mac OS-Arducam
UB021201
Discontinued, check alternative item B0468.
$43.99
Arducam UB021201 is a new member of the Arducam’s USB camera family.
It’s a 2MP, based on the 1/2.9” IMX323 image sensor, UVC compliant USB 2.0 camera.
No longer be anxious about installing the driver!
The native UVC drivers of Windows, Linux and Mac shall be compatible with this camera so that it does not require extra drivers to be installed.
This 2MP IMX323 color COMS sensor produces the camera capture the minimum illumination 0.01Lux, which gives you clearer visual joy for low light and night vision.
  • HD Resolution and Low Light: This camera adopts the 2MP IMX323 Color COMS sensor, can capture the minimum illumination of 0.01 [email protected].
  • Low Distortion: This camera module has a 68°(H) Low-Distortion (<3%) M12 Lens, which minimizes the imaging distortion and provides a wilder Field of View (FoV) than the most stock lens.
  • Capture Video with Audio: Built-in dual microphones for smooth video at a fluid 30 fps. H.264 30fps@1920 x 1080; MJPG 30fps@1920 x 1080; YUY2 30fps@640 x 480.
  • Plug & Play: UVC-compliant, just connect the camera to a PC computer, laptop, Android device, or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Applications: Come with a metal case and rotatable bracket, this tiny camera can be installed in the most hidden and narrow position for a home video surveillance system, day & night low light vision camera system, dashcam, or other machine vision application.
- Sensor: 1/2.9” IMX323
- Resolution: 2MP 1920 x 1080
- Data Format: H.264/MJPG/YUY2
- Frame Rate: H.264 30fps@1080p; MJPG 30fps@1080p; YUY2 30fps@640 x 480;
- Field of View (FOV):68°(H) - Lens Mount: M12
- IR Sensitivity: Integral IR filter, visible light only Functionality and Compatibility
- Adjustable parameter: Brightness, Contrast, Saturation, Hue, Sharpness, Gamma, Gain, White balance, Exposure.
- System Compatibility: Windows, Linux, Mac, and Android with UVC. Power
- Working Current: MAX 300mA Physical
- Dimension: 39mmx26x44mm
- Cable Length: 3.3ft (1M)
Manual.pdf
Manual.pdf
