[Discontinued] OV7725 Camera Module with IR cut M12 mount lens-Arducam
[Discontinued] 1080P Low Light Low Distortion USB Camera Module with Mini Metal Case, 2MP CMOS IMX323 Mini UVC USB2.0 Webcam Board with Microphones, 3.3ft/1m Cable for Windows, Linux, Android, and Mac OS-Arducam
[Discontinued] 5MP Wide Angle USB Camera with Mini Metal Case, 1/4" CMOS OV5648 Mini UVC USB2.0 Video Webcam Without Microphone for Windows, Linux, Android, and Mac OS-Arducam
UB023301
Discontinued, check alternative item B0454C.
$43.99
Arducam UB023301 is a new member of Arducam's USB camera family. It's a 5MP, based on the 1/4" OV5648 image sensor, UVC compliant, wide-angle USB 2.0 camera. Ultra HD resolution meets your request for higher quality video still pictures resolution.
This is a portable USB camera that comes with a metal case and rotatable bracket, you can easily put it on a desk or install it on a trip or on the wall with screws and adjust to your preferred angles, great for home security monitoring, online teaching, live streaming, online meeting or embedded industrial project.
  • Ultra HD Resolution: This camera adopts the 5MP OV5648 Color COMS sensor for sharp images and accurate color reproduction. Max resolution: 2592 x 1944, High frame rate 1080P@30fps, Compression format: MJPG / YUY2; Saturation, Contrast, White balance adjustable.
  • Wide Angle: Assembled with a 90-degree horizontal view angle M12 lens with IR filter, which provides a much wider Field of View compared to other lenses.
  • Frame Rates: MJPG 15fps@2592 x 1944/2048 x 1536; 30fps@1080P/720P/1024 x 768/800 x 600; YUY2 5fps@720P/1080P; 10fps@1024 x 768; 15fps@800 x 600.
  • Plug & Play: Ready to use, UVC-compliant, just connect the camera to a PC computer, laptop, Android device, or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Applications: Come with a metal case and rotatable bracket, this tiny camera is highly recommended for the video surveillance system, live streaming, videoconference, dashcam, and other vision
- Sensor: 1/4” OV5648
- Resolution: 5MP 2592 x 1944
- Data Format: MJPG 15fps@2592 x 1944/2048 x 1536; 30fps@1080P/720P/1024 x 768/800 x 600; YUY2 5fps@720P/1080P; 10fps@1024 x 768; 15fps@800 x 600.
- Field of View (FOV):90 degree (H)
- Lens Mount: M12
- IR Sensitivity: Integral 650nm IR filter, visible light only
- Adjustable parameter: Contrast/ Saturation/ Exposure/ White balance
- System Compatibility: Win7/8/10, Linux, Mac, and OS with UVC driver
Power
- Working Current: MAX 250mA
Physical
- Dimension: 40mmx25mmx45mm
- Cable Length: 3.3ft (1M)
Manual.pdf
Manual.pdf
3D Drawing.STEP
3D Drawing.STEP
