Arducam High Quality Complete USB Camera Bundle, 12MP 1/2.3 Inch 477P Camera Module with 2.8-12mm Varifocal Lens C20280M12, Metal Enclosure, Tripod and USB Cable
Arducam IMX477 UVC Camera Adapter Board for 12MP Raspberry Pi HQ Camera with Single Microphone
Arducam High Quality Complete USB Camera Bundle, 12MP 1/2.3 Inch 477P Camera Module with 6mm CS-Mount Lens, Metal Enclosure, Tripod and USB Cable
B0280
  • High Resolution: Based on 12MP sensor for sharp image and accurate color reproduction
  • Wider Angle of View: In different focus distance with a field of view 65°
  • Plug&Play: UVC-compliant, just connect the camera to PC computer, laptop, Android device or Raspberry Pi with the USB cable without extra drivers to be installed
  • Wide Applications: Video surveillance system, live streaming, record lesson and conference, etc.
$149.99
Arducam has been a professional designer and manufacturer of SPI, MIPI, DVP, and USB cameras since 2012. We also offer customized turnkey design and manufacturing solution services for customers who want their products to be unique.
Arducam B0280 is a new member of Arducam's USB camera family. It's a 12MP, based on the 1/2.3" Sony image sensor, UVC compliant, 6mm USB 2.0 camera with the metal shell.
No longer be anxious about installing the driver! The native UVC drivers of Windows, Linux, and Mac shall be compatible with this camera so that it does not require extra drivers to be installed.
  • Video conference
  • Live streaming
  • Record lesson and conference
Resolution 4032(H) x 3040(V) 12.3MP
Data Format MJPG
Frame Rates 4032x3040@10fps; 3840x2160@20fps; 2592x1944@30fps; 2560x1440@30fps; 1920x1080@60fps; 1600x1200@50fps; 1280x960@100fps; 1280x720@100fps; 640x480@80fps
Field of View (FOV) 65°(H)
Lens Mount CS Mount
Focal Length 6mm
Back Focal Length 7.53mm
MOD 0.2m
Focus Type Manual
Auto Controlled Features Saturation, Contrast, Acutance, White balance, Exposure
System Compatibility Windows, Linux, Mac, and Android with UVC
Power Supply USB powered 5V
Working Current MAX 200mA
Operating Temp -4°F~158°F (-20°C~+70°C)
Dimension 50mmx50mmx85mm
Cable Length Default 6.56ft (2M)
Quick Start Guide
  • 1 × 12MP 6mm lens USB 2.0 camera with full metal shell
  • 1 × 6.56ft (2M) USB 2.0 cable
  • 1 x mini tripod stand
Lens Options
CS-Mount Lens
SKU LN051 LN050 LN038 LN039 LN040 LN041 LN029
Part No
CS17320M12
CS2316ZM02
CS2308ZM05
CS2008ZM05A
CS1812ZM03
CS2325ZM01
CS1806ZM06
Optical Format 1/1.7″ 1/2.3' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3''
EFL(mm) 3.2 16.00  8.00 8.00 12.00 25.00 6.00
BFL(mm) 5.94 7.53 6.50 7.53 7.53 8.03 8.03
F/NO 2.0 1.2  1.4 1.2 1.6 1.2 1.4
HFOV on 1/2.3‘’ Cam 120° 24° 50° 50° 30° 14° 65°
MOD 0.30m 0.20m  0.30m 0.20m 0.20m 0.20m 0.30m
Size(mm)
28×30 30×29 28×23 30×29.5 30×29 28×29 28×28.5
NOTE 1: The CS-Mount Lens kit for the HQ Camera module, please check LK004, 5 lenses are included.
NOTE 2: For the sample order, please order the lens you need to replace separately and Contact us in advance for customization if you would like to replace the lenses on the Camera board.
