8MP A219 autofocus USB2 UVC camera module, available with HDR and Metal Housing Module
Arducam 16MP Wide Angle USB Camera, 1/2.8
Arducam 16MP Wide Angle USB Camera, 1/2.8" CMOS IMX298 4K Video Webcam With Microphone
Arducam IMX477 UVC Camera Adapter Board for 12MP Raspberry Pi HQ Camera with Single Microphone
B0278
  • Make IMX477 UVC-Compliant: Extend your IMX477 Camera work as a webcam
  • Plug and Play: Connect this adapter with camera board to PC computer, laptop, Android device, Raspberry Pi or Jetsons via USB port without extra drivers
  • With Audio: Built-in single microphones, so as to capture video with audio
  • Ultra HD and High Frame Rates: No effect on the image quality and frame rates
  • Easy to Assemble: Compatible location and pitch of mounting hole. Just connect and assemble the adapter board with the camera board with the included camera cable and accessories.
$39.99
This CSI to USB adapter board aims to break the limits of applications of Raspberry Pi IMX477 High Quality camera and Arducam IMX477 camera series. Just connect this adapter with the camera board to PC computer, laptop, Android device, Raspberry Pi or Jetsons via USB port and it can work as a webcam.
No longer be anxious about installing the driver! It makes your 12.3MP IMX477 High Quality Camera UVC-compliant, the native UVC drivers of Windows, Linux and Mac shall be compatible with them so that it does not require extra drivers to be installed.
  • Other vision applications demand IMX477 camera
  • DSLR Camera Control
  • Instant (Polaroid-Style) Camera, etc.
Support Sensor Sony 12.3MP IMX477
Data Format MJPG
Auto Controlled Features Saturation, Contrast, Acutance, White balance, Exposure
System Compatibility Windows, Linux, Mac and Android with UVC
Signal Input 22 Pin 0.5mm Pitch CSI connector
Audio Single Microphone, support Audio input/output
Frame Rates 10fps@4032x3040; 20fps@3840x2160; 30fps@2592x1944/2560x1440; 60fps@1080P; 100fps@720P
Signal Output 1.5mm Pitch ZH connector ZHR-4
Voltage Input DC 5V
Connecting Port Type USB2.0
Working Current 200mA
Operating Temp -4°F~167°F (-20°C~+75°C)
Overall Dimension 38mm x 38mm
Cable Length Default 3.3ft(1m)
Hole Pitch Compatible with 29mm, 30mm, 34mm
  • 1 x CSI-UVC adapter board
  • 1 x 3.8cm 22pin to 15pin camera cable for Raspberry Pi Official High Quality Camera
  • 1 x 8cm 22pin to 22pin camera cable for Arducam IMX477 HQ camera series
  • 1 x 1m/3.3ft USB2.0 camera cable
  • 1 set accessories of standoff, screws, and nuts
User Guide
3D Drawing
Mechanical
  • IMX477 Camera module is not included in the package
  • Arducam IMX477 cameras for Jetson are deprecated because of different white balance calibrations. If you like the idea but don’t have the camera yet, check our full IMX477 USB Camera Bundle [CS Lens Bundle] [Zoom Lens Bundle] instead of buying those separately.
  • This product is only compatible with fixed-focus Arducam IMX477 HQ cameras (B0240/B024001/B0262/B0270) and the official Raspberry Pi HQ camera.
