8MP IMX219 Camera Module for Raspberry Pi, with Low Distortion 88°(D) FOV M12 Lens, Compatible with Raspberry Pi 5, 4B, Pi 3/3B+, Pi Zero 2W and More
8MP IMX219 175 Degree Ultra Wide Angle Raspberry Pi Camera Module, Compatible with Raspberry Pi 5, 4B, Pi 3/3B+, and Pi Zero 2W
Arducam for Raspberry Pi Camera, 8MP IMX219 Auto Focus Camera Module with Motorized Lens, Software Precise Manual Focus for Raspberry Pi 4B/3B+, Zero, Zero 2w
The official raspberry pi camera module v2 has fixed-focus lenses, which are either glued or need manual adjustment. However, Arducam thinks that your focus matters and has released this motorized focus camera for Raspberry Pi. This camera module is designed for you to control the focus on a camera for Raspberry Pi via software, so you can see closer and see where you want to see.
Application
Unmanned Aerial Vehicles (UAVs)
Building Drones
Autonomous Robotic Systems
Mobile Medical Imaging
Intelligent Video Analytics (IVA)
Feature
High-Speed Data Interface: Standard 2-lane MIPI CSI-2 interface with configurable 4-lane high-performance mode. Delivers maximum bandwidth for high-resolution sensor data transmission while maintaining compatibility with mainstream embedded platforms.
Raspberry Pi Camera: Designed for Raspberry Pi, this 8MP HD camera module has a Sony IMX219 8MP pixel sensor with an autofocus lens. Focal Length: 2.8 mm; Angle of View: 77.6 degrees (diagonal).
AutoFocus Lens: Software-controllable motorized focus lenses with manual and autofocus Python scripts supported by OpenCV, allowing remote control of focus without lens adjustment tools. With a simple script configuration, you can use Up/Down on the keyboard for precise manual focus control.
Wide Compatibility: The camera is not only compatible with all models of Raspberry Pi 1, 2, 3, and 4, but also with Raspberry Pi Zero and Zero 2W, which can be easily used with a simple configuration.
8MP More than HD: Supports 3280 × 2464 pixel still images and still captures.
Easy and Convenient: It is easy for beginners, and it also offers more to explore for advanced gamers.
IMX219
Still Resolution
8 Megapixels
Video Modes
1080p47, 1640 × 1232p41 and 640 × 480p206
Sensor Resolution
3280 × 2464 pixels
Sensor image area
3.68 x 2.76 mm (4.6 mm diagonal)
Pixel Size
1.12 µm x 1.12 µm
Optical Size
1/4"
IR Sensitivity
Integral IR-cut Filter, visible light only
Focus Type
Programmable/Auto Focus
Focal Length
2.8mm
F.NO
F2.2
Field of View(FOV)
65°(H)×51°(V)×77.6°(D)
Focus Distance
80mm~infinity
Electrical & Mechanical
MIPI CSI-2
Data Lanes
2-lane (default), configurable to 4-lane
Camera Board Size
25 x 24mm
Peaking Current
300mA
1 x 8MP IMX219 Auto Focus Camera Module with Motorized Lens
1× 15cm 15-22pin FPC Cable
1× 15cm 22-22pin FFC Cable
The package does not include any Raspberry Pi motherboard.
The drop-in replacement module does not include FPC cables and any camera boards. And it requires the use of the Raspberry Pi V2 camera board to function properly.
The lenses of all camera modules are not interchangeable. Please contact sales in advance if you need to replace them.
