Arducam 8MP*4 IMX219 Quadrascopic Camera Bundle Kit for Raspberry Pi, NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam for Raspberry Pi Camera, 8MP IMX219 Auto Focus Camera Module with Motorized Lens, Software Precise Manual Focus for Raspberry Pi 4B/3B+, Zero, Zero 2w
8MP IMX219 Camera Module for Raspberry Pi, with Low Distortion 88°(D) FOV M12 Lens, Compatible with Raspberry Pi 5, 4B, Pi 3/3B+, Pi Zero 2W and More
B0394
  • [2-lane/4-lane Support]Adopt MIPI CSI-2 interface, supporting 2lane/4lane output configurations.
  • Wide Applications: Including time-laspe, slow motion, field phtotograph, 3D printer and so on.
  • Native to Raspberry Pi: No need to install additional driver for this camera
  • Higher Resolution: Support max 3280 × 2464 pixel still images
  • Ultra Low Distortion: Attached with a low distortion (<3%) M12 lens
was $29.99 Special Price $23.99
This Arducam IMX219 camera module is mainly designed for Raspberry Pi. The highlight of this camera is its very low distortion (<3%) of the lens. No less than the Raspberry Pi official camera V2, this camera module is also equipped with a high-definition IMX219 8MP sensor for shooting HD video and still images.It is excellent in image quality, color fidelity, and low light, and supports still capture.For beginners, this is a very easy camera module to get started; for advanced players, this camera module has more knowledge that you should explore and DIY.
  • Astrophotography
  • Surveillance cameras
  • FA cameras
  • High-Speed Data Interface: Standard 2-lane MIPI CSI-2 interface with configurable 4-lane high-performance mode. Delivers maximum bandwidth for high-resolution sensor data transmission while maintaining compatibility with mainstream embedded platforms.
  • Raspberry Pi Camera: Designed for Raspberry Pi, this 8MP HD camera module has a Sony IMX219 8MP pixel sensor with low distortion (<3%) M12 lens. EFL: 2.8mm, F.NO: 2.8, View Angle: 75 Deg. (Horizontal).
  • 8MP More than HD: Supports 3280 × 2464 pixel still images, and still captures. The Raspberry Pi Camera Board v2 - 8 Megapixels is a leap forward in image quality, color fidelity, and low light than the camera v1.
  • Wide Compatibility: The camera is compatible with all Raspberry Pi 1, 2, 3, and 4 models, and with Raspberry Pi Zero and Zero 2W, which can be easily used with a simple configuration.
  • Easy to setup: The package comes with a 15cm 22-22pin FPC cable, and a 15cm yellow 15-22pin FPC cable. Simply connect the Raspberry Pi board and camera with the FPC cable and you can easily use this 8MP high-quality camera.
  • Application: Easy to use for beginners, and for advanced gamers, it offers more to explore. Perfect for time-lapse, slow motion, home security applications, monitoring Octoprint 3D Printer, and wildlife camera trap applications.
Image Sensor IMX219
Still Resolution 8 Megapixels
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
Focal Length 2.8mm
Field of View(FOV) 88°(D)x75°(H)x60°(V)
Distortion <3%
Electrical & Mechanical
Interface MIPI CSI-2
Data Lanes 2-lane (default), configurable to 4-lane
Camera Board Size 24mm x 25mm
Peaking Current 300mA
  • 1 x 15cm 15-22pin FPC cable
  • 1 x 15cm 22-22pin FFC cable
  • 1 x IMX219 Camera Module with Low Distortion M12 Lens
Raspberry Pi 5 √ √
