Arducam 8MP IMX219 Autofocus USB2.0 Camera Module with 300mm Extension Cable
Arducam IMX219 8MP Spy Camera with 300mm Extension Cable for Nvidia Jetson Board and Compute Module
CSI-to-HDMI Adapter Set for Raspberry Pi Cameras (Pack of 2, 1 Set)
B0091
  • Highly Compatible: Compatible with all Raspberry Pi 5/4B/3B+/3B/2B/A&B
  • Software: Ready for the latest Raspberry Pi OS and camera software (libcamera).
  • Headphone Jack: Reserved extra Pins for GPIO extension.
  • Zero Configuration: Easy to set up, plug-n-play out of the box
  • Reliability: Robust and durable. No worry about the fragileness and vulnerability of FPC cables’ crisp nature.
arducam shipping payment 1
$13.99
A CSI-to-HDMI adapter set for you to break the length limitations of the MIPI CSI-2 interface and put your cameras up to 3~5 meters away from an RPI or NVIDIA Jetson Board, etc..
Note: No extra software/configuration is needed. HDMI cables can be up to 3~5 meters depending on the backend processer, camera, and the HDMI cable specs. For longer than 5 meter application, you are recommended to use the Arducam Ethernet Extension Kit (SKU: U6248)
Supported Camera Modules
Supported Platform Camera Modules
Raspberry Pi Rasberry Pi V1/Arducam OV5647 Camera
Rasberry Pi V2/Arducam IMX219 Camera
Rasberry Pi V3/Arducam IMX708 Camera
Rasberry Pi HQ/Arducam IMX477 Camera
Arducam 16MP IMX519 Camera
Arducam 64MP Hawkeye Camera
Arducam 64MP OwlSight Camera
NVIDIA Jetson IMX219 Camera Modules
IMX477 Camera Modules
IMX708 Camera Modules
IMX519 Camera Modules
Supported Platforms: NVIDIA Jetson Orin Nano/Orin NX, Raspberry Pi 5, 4B, 3B+, 3B, 2, Model A/B/B+, and Pi Zero, etc.
  • No extra software/configuration is needed.
  • HDMI cables can be up to 3~5 meters.
  • Reserved microphone and headphone jack for audio or GPIO signals
  • Three additional solder pads are available (same signals as a headphone jack)
  • Size: 27.63 x 25.00mm
Documentations
Packing Including
  • 2pcs Arducam CSI to HDMI Cable Extension Module
  • 2pcs 60mm 15pin FPC cables
  • 2pcs 73mm 22pin FPC cables
  • 4sets M2 screw
  • Make sure to use high-quality HDMI v2.1 cables.
  • Please be sure to use a high-quality HDMI cable, which allows the camera to run 3-5 meters, greatly extending the usage of the Pi camera.
Raspberry Pi 5
FaQs
Can I use the adapter kit for monitors?
No, the kit is designed only to extend the cable length of MIPI CSI-2 Pi cameras, it will not work with other platforms/interfaces.
What's the maximum allowed distance?
For a stable connection, please keep the length no more than 10 meters.
Is it compatible with other 3rd party camera modules?
No.
Can I use it with your quad-camera and stereoscopic camera series?
Yes.
