Arducam IMX219 Wide Angle Camera Module, drop in replacement for Raspberry Pi V2 and NVIDIA Jetson Camera
Arducam IMX219-AF Programmable/Auto Focus Camera Module for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam IMX219 8MP Spy Camera with 300mm Extension Cable for Nvidia Jetson Board and Compute Module
B0185
B0185 Arducam IMX219 8MP Spy Camera with 300mm Extension Cable for Nvidia Jetson Boadr and Compute Module. It could be used in space constraint applications like through a hole or a tube or wearable devices.
was $34.99 Special Price $24.99
This Arducam Spy Camera is mainly designed for Nvidia Jetson Board and Compute Module, in order to extend the small camera module with much longer distance and fit into space-constrained environments, it also can be used on other hardware like ARM, DSP, FPGA, etc.
★KERNEL CAMERA DRIVER USED
Features & Specs
  • Sony 8MP IMX219 Sensor
  • Optical Format: 1/4 inch
  • EFL: 3.04mm
  • F.NO: 2.0
  • Focus Type: Fixed Focus
  • View Angle: 74°(D)×62.2°(H)×48.8°(V)
  • Interface: MIPI CSI-2 2-lane
  • IR Sensitivity: Visible light, Integral IR Filter
  • Cable length: 300mm
  • Cable width: 9mm
  • Cable thickness: 0.1mm
  • With Electromagnetic shielding
  • 1pcs Arducam IMX219 8MP Spy Camera with 300mm Extension Cable
  • 1pcs 15-22pin FPC Cable
The camera can be used on compute module CM3, CM3+, and NOT compatible with Raspberry Pi 3B/B+.
2 comments
GitHub
ArduCAM/Nvidia_Jetson
