[Discontinued] Arducam 70 Degree M12 Lens Bundle for Raspberry Pi HQ Camera, with Portable Tripod Stand and 2ft/60cm Black Camera Cable
[Discontinued] Arducam 180 Degree Fisheye M12 Lens Bundle for Raspberry Pi HQ Camera, Wide Angle Lens with Portable Tripod Stand and 2ft/60cm Black Camera Cable
[Discontinued] Arducam 90 Degree M12 Lens Bundle for Raspberry Pi HQ Camera, Wide Angle Lens with Portable Tripod Stand and 2ft/60cm Black Camera Cable
B0234
They Just Work – We’ve tested this lens, the camera cable and the tripod stand on the 12MP RPi HQ Camera. With them, you can get decent quality image and release your hands.
Wide Angle M12 Lens – 90 degree HFOV (horizontal field of view), another cost-effective choice that adds up to your Raspberry Pi High Quality Camera Module, which provides a much wider Field of View than C and CS lenses.
The Tripod Stand – Pocket size and lightweight, 1/4”-20 mounting screw, hassle-free fitting the RPi HQ Camera Board.
The Camera Cable – 60cm/2ft length, 15 Pin 1.0mm Pitch interfaces, black color and long enough, goes well with 3D printers OctoPrint setup and Raspberry Pi High Quality Camera.
If you want to grab all the available S-mount lenses for the HQ camera, Arducam has also got a 6-in-1M12 lens bundle here.
Lens Specification
Model No: M23356H09
Optical Format: 1/2.3”
Focal Length: 3.56mm
Aperture: F2.5
Field of View (FOV): 90° (H)
Mount: M12 mount
Back Focal Length: 5.92mm
MOD: 0.2m
Dimension: Φ14×16.3mm
Weight: 7g
Other Arducam S-mount lens bundles with different FoVs
