[Discontinued] Arducam 50 Degree M12 Lens Bundle for Raspberry Pi HQ Camera, with Portable Tripod Stand and 2ft/60cm Black Camera Cable
[Discontinued] Arducam 90 Degree M12 Lens Bundle for Raspberry Pi HQ Camera, Wide Angle Lens with Portable Tripod Stand and 2ft/60cm Black Camera Cable
[Discontinued] Arducam 70 Degree M12 Lens Bundle for Raspberry Pi HQ Camera, with Portable Tripod Stand and 2ft/60cm Black Camera Cable
B0235
Note: This lens can be used on Arducam HQ camera module (SKU: B0240, B0249, B0251, B0262).
If you would like to get the 70° lens on the Raspberry Pi HQ camera module, check the M12 lens kit B0276 (HFOV: 75°).
If you want to grab all the available S-mount lenses for the HQ camera, Arducam has also got a 6-in-1 M12 lens bundle here.
They Just Work - We’ve tested this lens, the camera cable and the tripod stand on the 12MP RPi HQ Camera. With them, you can get decent quality image and release your hands.
The M12 Lens - 70 degree HFOV (horizontal field of view), another cost-effective choice that adds up to your Raspberry Pi High Quality Camera Module.
The Tripod Stand - Pocket size and lightweight, 1/4”-20 mounting screw, hassle-free fitting the RPi HQ Camera Board.
The Camera Cable - 60cm/2ft length, 15 Pin 1.0mm Pitch interfaces, black color and long enough, goes well with 3D printers OctoPrint setup and Raspberry Pi High Quality Camera.
Lens Specification
Model No: M23390H08
Optical Format: 1/2.3”
Focal Length: 4.3mm
Aperture: F2
Field of View (FOV): 70° (H) on Arducam High Quality Camera, 45°(H) on Raspberry Pi V1/V2 Camera
Mount: M12 mount
Back Focal Length: 3.62mm
MOD: 0.3m
Dimension: Φ14×19.58mm
Weight: 8g
IR Sensitivity: sensitive to visible light, with 650nm IR filter
Other Arducam S-mount lens bundles with different FoVs
