Arducam Pan Tilt Camera Bundle for Nvidia Jetson Xavier NX/Nano, 2 Two-DOF Platforms with 8MP IMX219 Cameras, with PTZ Control Board
Arducam 13MP MIPI Camera Module with AR1335 OBISP and M12 Mount Lens for Raspberry Pi, and NVIDIA Jetson Nano
Arducam 8MP 1080P USB Camera Module with M12 Mount, 1/3.2" CMOS IMX179 UVC USB2.0 Webcam Board with 3.3ft/1m Cable for Windows, Linux, Android and Mac OS
UB0229
  • More than HD: This camera adopts 8MP IMX179 sensor for sharp image and accurate color reproduction
  • Capture Video with Audio: high frame rates, MJPG 15fps@3264 x 2448, 30fps@1080P; YUY2 30fps@640x 480.
  • Plug&Play: UVC-compliant, just connect the camera to PC computer, laptop, Android device or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Applications: this tiny 38mmx38mm camera board can be installed in the most hidden and narrow position for a home surveillance system, monitoring 3D Printer, object recognition and tracking or other machine vision application.
  • Note: There is a lens shading problem after changing the lens, so we don’t recommend changing the lens.
$55.99
Arducam IMX179 UVC camera module with M12 mount lens is a  new member of Arducam’s USB camera family. It’s an 8MP, UVC compliant, M12 mount lens based on the 1/3.2” Sony IMX179 image sensor, USB 2.0 camera.
  • - Sensor: 1/3.2” IMX179
  • - Resolution: 8MP 3264H x 2448V
  • - Data Format: MJPG/YUY2
  • - Frame Rate: MJPG 15fps@3264 x 2448, 30fps@1080P; YUY2 30fps@640x 480
  • - Field of View (FOV):D=105°, H= 90°, V= 65°
  • - Lens Mount: M12
  • - Focusing Range: 0.5m to infinity
  • - IR Sensitivity: Integral IR filter, visible light only
  • - Auto Controlled Features: Saturation, Contrast, Acutance, White balance, Exposure.
  • - Audio: single microphone (optional dual channel)
  • - System Compatibility: Win7/8/10, Linux, Mac and Android with UVC
Power
  • - Power Supply: USB powered 5V
  • - Working Current: MAX 350mA
Physical
  • - Operating Temp.: -4°F~167°F (-20°C~+75°C).
  • - Dimension: 38mmx38mm (Mount compatible with 34x34mm, 28x28mm)
  • - Cable Length: 3.3ft (1M)
  • 1 pcs Arducam IMX179 8MP UVC Camera with M12 Mount Lens
  • 1 pcs 1m/3.3ft USB Cable
User guide.pdf
UVC Camera Module
windows usb camera module blog thumbnail
The Different Kinds of Camera Modules You Can Use with Windows PCs
Cameras on the Windows Platform If you click the start menu on Windows 10, you will probably find an app called “Camera.” On a laptop, the app shows the built-in front-facing camera with some simple controls, but how would you use a camera on the desktop end? Aside from a built-in webcam, there are several […]
