Arducam Case and Tripod Bundle for Stereo Camera Module B0263, B0264
Arducam 8MP 1080P USB Camera Module with M12 Mount, 1/3.2
Arducam 8MP 1080P USB Camera Module with M12 Mount, 1/3.2" CMOS IMX179 UVC USB2.0 Webcam Board with 3.3ft/1m Cable for Windows, Linux, Android and Mac OS
Arducam Pan Tilt Camera Bundle for Nvidia Jetson Xavier NX/Nano, 2 Two-DOF Platforms with 8MP IMX219 Cameras, with PTZ Control Board
B0191PT
  • You’ll be Getting: A pan tilt bracket kit, 2 digital servo motors, a PTZ controller board (with jumper wires).
  • Pan Tilt Kit: Free panning and tilting in a smaller PT bracket. Specifically designed for a broader view on Raspberry Pi camera projects. PWM controller board included.
  • Mini Digital Servos: Two GH-S37D digital servos for a faster speed, higher torque and better holding capability (than analog servos).
  • PWM Control Board: I2C controlled; Up to 16-Channel servo, 12-bit resolution for each channel; outputs the PWM signals to drive the servo motors directly.
  • Applications: Home security and surveillance, robotics, sun tracker or other raspberry pi projects where you need a single camera to cover more areas.
  • B0191PT can work with Nvidia Jetson Xavier NX and Jetson Nano.
  • Besides the included cameras, the PT bracket is compatible with the Official 8MP camera and others with the same distance of the mounting hole.
  • NOTE: The cameras can’t work on Raspberry Pi.
$54.99
B0191PT is a new member of the family, which can be used to run two cameras on Jetson Xavier NX and Jetson Nano.
Specs
  • Sensor: IMX219
  • Resolution: 8MP 3280H x 2464V
  • Frame Rate: 21fps@8MP; 60fps@1080P, 180fps@720P
  • Field of View: 62.2°(H)
  • Camera Board Dimension: 25mm x 24mm
Digital Servo
  • Torque: 0.6 kg/cm at 3.6V, 0.8 kg/cm at 4.8V
  • Operating Speed: 0.13sec/60° at 3.6V, 0.09sec/60° at 4.8V
  • Operating Voltage: 3.6v~4.8v
  • Operating Current: <350mA
  • Dead Band: 3 usec
  • Dimension: 20mm x 8.75mm x 22mm
Control Board
  • PWM Driver: PCA9685
  • PWM resolution: 12-bit
  • Ambient light sensor: TSL2581FN
  • Ambient light resolution: 16-bit
  • Communication interface: I2C
  • Operating voltage: 3.3V/5V
  • Dimension: 25mm x 61mm
  • 2 x 8MP IMX219 cameras for Jetson Nano/Xavier NX with 30cm camera cables
  • 4 x Digital servos
  • 2 sets epoxy bracket pieces with screws
  • 1 x PWM control board
  • 5 x Female to female jumper wires (The wire has no fixed color)
user guide.pdf
