Arducam 8MP 1080P USB Camera Module with M12 Mount, 1/3.2
Arducam 8MP 1080P USB Camera Module with M12 Mount, 1/3.2" CMOS IMX179 UVC USB2.0 Webcam Board with 3.3ft/1m Cable for Windows, Linux, Android and Mac OS
Arducam 2MP MIPI Camera Module with AR0230 OBISP for Jetson Nano
Arducam 13MP MIPI Camera Module with AR1335 OBISP and M12 Mount Lens for Raspberry Pi, and NVIDIA Jetson Nano
B0248
Note: This product was discontinued. Please check the new version: B0277
Check Pre-tuned ISP Series: Arducam xISP series and Arducam TrueSight Series
$49.99
Arducam 13MP OBISP MIPI camera features onboard ISP (Image Signal Processor), it uses standard Raspberry pi 15pin MIPI CSI-2 interface, and works seamlessly on Raspberry pi, Jetson Nano, and can also be ported to other platforms which compliant to MIPI CSI-2 interface protocol.
⚠️ KERNEL CAMERA DRIVER USED
  • Cellular phones
  • Digital still cameras
  • PC cameras
  • IoT cameras
  • Resolution: High Resolution
  • Shutter Type: Rolling Shutter
  • Color Type: Color
  • IR Sensitivity: 650nm IR filter, visible light only.
  • Output Interface: 2-Lane MIPI CSI-2
  • Output Format: YUV422, RGB888
  • ISP Features: AWB, AE, Flip, Mirror, DeNoise, Gamma, Sharpness, Saturation, Contrast Digital Zoom, Digital Pan/Tilt, Speical Effects etc
  • Platform Support:  Raspberry Pi, Jetson Nano or platform with MIPI CSI-2 interface
Specs
  • Sensor Type: 13MP AR1335
  • Pixel Size: 1.1um x 1.1um
  • Resolution: 4160x3120
  • Optical Size: 1/3"
  • Lens Spec: M12 default(SKU:LN053), EFL: 3.9mm, FoV(H): 60°, F/NO: 2.8
  • Max Data Rate: 1.2Gbps/laneFrame Rate: 7fps@4160x3120, 11fps@3264x2448/3840x2160, 24fps@2560x1440, 30fps@1600x1200/1920x1080/640x480/320x240
  • Responsivity: 4.7k e/lux-sec
  • SNR(Max): 37dB
  • Dynamic Range: 69dB
  • Power Consumption: 270mW
  • Temperature Range: -10 ~ 70 degrees
  • Camera Driver: V4L2 Compliant driver for Raspberry Pi and Jetson Nano
  • Board Size: 38mm x 38mm
  • 1pcs Arducam 13MP OBISP Camera Module with M12 Mount Lens
  • 1pcs 15pin to 22pin ribbon cable
User guide.pdf
How to Purchase
Arducam OBISP MIPI Camara Module
