3MP ISX031 8-Channel GMSL2 Camera Kit for NVIDIA Jetson AGX Orin – 120 dB HDR, Built-in ISP, LED Flicker Mitigation, IP67 Waterproof, up to 15 m Cable Extension
Arducam 3MP ISX031 MIPI Camera for NVIDIA Jetson Orin Nano/NX – 120 dB HDR, Built-in ISP, LED Flicker Mitigation, Wide-Angle Lens
Arducam 3MP ISX031 USB3 UVC Camera – 120 dB HDR, Built-in ISP, LED Flicker Mitigation, Plug-and-Play for Windows and Linux
B0624
  • [Sony ISX031 Sensor] 3 MP CMOS with 120 dB HDR and LED Flicker Mitigation.
  • [Built-in ISP] Hardware image processing for vivid, real-time output.
  • [LED Flicker Mitigation (LFM)] Eliminates flicker from LED or traffic lighting.
  • [USB 3.0 UVC Interface] High-speed data transfer and plug-and-play operation.
  • [Cross-Platform Support] Works with Windows and Linux devices.
  • [Wide-Angle Lens] Expanded field of view for robotics, AI vision, and industrial use.
SAMPLE PRICE
$149.99
VOLUME PRICE
The Arducam 3MP ISX031 USB3 UVC Camera combines Sony’s automotive-grade ISX031 sensor with a high-speed USB 3.0 interface for seamless, plug-and-play imaging on major platforms. Featuring 120 dB HDR, built-in ISP, and LED Flicker Mitigation, it delivers clear, flicker-free images even under complex lighting. With a wide-angle lens and UVC compatibility, this camera is ideal for developers and engineers seeking a reliable, high-performance vision solution that works instantly out of the box.
  • AI vision and robotics development
  • Smart traffic and LED-lit monitoring systems
  • Industrial inspection and automation
  • Drone vision and environmental imaging
  • Research and prototyping with Jetson, PC, or SBC platforms
  • ▶ 120 dB High Dynamic Range (HDR) The ISX031 sensor delivers up to 120 dB HDR, enabling precise detail capture in both bright sunlight and deep shadow. Ideal for outdoor and mixed-lighting scenarios.
  • ▶ Built-in Image Signal Processor (ISP) An integrated ISP performs color correction, noise reduction, and tone mapping directly on the sensor, ensuring consistent, true-to-life imagery without extra processing load on the host.
  • ▶ LED Flicker Mitigation (LFM) Advanced LED flicker suppression guarantees stable video streams in environments with LED lighting, such as traffic systems or warehouses.
  • ▶ USB 3.0 UVC Plug-and-Play No drivers required — simply connect via USB 3.0 and start capturing. Supports popular apps and frameworks across Windows and Linux.
  • ▶ Wide-Angle Lens for Broader Coverage Factory-mounted wide-angle lens provides greater situational awareness, ideal for AI perception, navigation, and inspection systems.
Sensor ISX031
Resolution 3 Megapixels
Chroma Color
Optical Format 1/2.42"
Pixel Size 3.0 µm x3.0 µm
Sensor Active Area 1920(H)×1536(V)
Output Format YUV
Resolution@fps 1920x1536@30fps, 1920x1080@30fps
ISP Built-in ISP
FOV 127°(D)×97°(H)×76°(V)
F.NO F2.5
E.F.L 3.57mm
Default Focus Distance 300cm-INF
Distortion <-18%
Weight 3.8g
USB Features
HDR Support Yes
Recommend Imaging Applications PotPlayer for Windows, qv4l2 for Linux
UVC Controls Sharpness, Hue, Brightness, Contrast, Saturation, Power Line Frequency
Power Consumption Max: 1.6W
Overall Weight (Net) 50g
Overall Size 38x38 mm
Certification RoHS
  • 1 x Arducam 3MP ISX031 HDR USB3 UVC Camera Module
