Global Shutter Camera Module for NVIDIA Jetson Orin Nano/NX, 2.3MP High res. & Onboard ISP for Robotics & Machine Vision
Arducam 3MP ISX031 MIPI Camera for NVIDIA Jetson Orin Nano/NX – 120 dB HDR, Built-in ISP, LED Flicker Mitigation, Wide-Angle Lens
Arducam 4K HDR AR0822 High Framerate MIPI Camera with onboard ISP for NVIDIA Jetson Orin Nano/NX
B0586
  • [Onboard ISP] Pre-tuned ISP right on the camera board
  • [4K HDR] Onsemi AR0822 3840x2160 high resolution HDR image sensor
  • [High Framerate] 60FPS @ 1080P Full HD for UYUV
  • [Wide Angle] Selected Ultra Wide-Angle M12 lens with DFoV 145°
  • [Custom Supported] Incl. but not limited to Framerate, Lens options, External Trigger, FStrobe, etc.
$119.99
The Arducam 4K HDR AR0822 MIPI Camera delivers ultra-high-definition 4K resolution with HDR and smooth 60FPS Full HD video, featuring a pre-tuned onboard ISP for optimized image processing. Designed specifically for NVIDIA Jetson Orin Nano and NX platforms, this camera includes a wide-angle 145° M12 lens and supports customizable options such as framerate, lens types, external triggers, and flash strobe control, making it ideal for advanced embedded vision applications.
    Drones: High-res aerial footage with smooth motion.
  • Sports: Capture fast action in soccer, tennis, and more.
  • Robotics: Vision for navigation and object detection.
  • Industrial Inspection: Detailed quality control imaging.
  • Live Streaming: Crisp video for events and webinars.
  • Security: Wide-angle, clear surveillance footage.
  • Scientific Research: High-quality data capture for experiments.
  • Onboard ISP: Features a pre-tuned Image Signal Processor on the camera board for fast, high-quality image processing without extra hardware.
  • 4K HDR: Delivers ultra-high-definition 3840x2160 resolution with HDR mode for clear, vibrant images in varied lighting.
  • High Framerate: Supports smooth 60FPS video at 1080p Full HD in UYUV formats, ideal for real-time applications.
  • Wide Angle: Equipped with an M12 lens offering a 145° diagonal field of view to capture wide scenes easily.
  • Custom Supported: Offers customizable options like framerate, lens choices, external trigger, and flash strobe control for versatile use.
Sensor Onsemi AR0822
Still Resolution 8.3 Megapixels
Optical Size 1/1.8"
Output Format UYVY
Pixel Size 2 µm x 2 µm
Sensor Active Area 3840(H)×2160(V)
Frame Rate (YUV) 3840x2160@15fps, 1920x1080@60fps; 1280*720@60fps,640x480@60fps;
FOV(DxHxV) 145°(D)×120°(H)×65°(V)
F.NO F1.5±5%
E.F.L 3.8±5% mm
Default Focus Range 260cm to infinity
TV-Distortion <-20.00%
Operating Voltage 3.3V
Power Consumption 1W
Camera Board Size 34mm x 34mm
Exposure Time Range 1-66ms
Camera Interface MIPI CSI-2
Supported JetPack Versions JetPack6.2/L4T36.4.3 and later versions
Supported Platform NVIDIA Orin Nano/Orin NX
  • 1 x Arducam 4K HDR AR0822 MIPI Camera Module for NVIDIA Orin Nano/NX
  • 1 x 15cm 22-22pin FPC Cable
Video Demo
