The Arducam 3MP ISX031 MIPI Camera brings Sony’s automotive-grade imaging performance to the NVIDIA Jetson Orin platform. Featuring a 120 dB high dynamic range, built-in ISP, and LED flicker mitigation, it delivers exceptional clarity in complex lighting—from bright sunlight to dim indoor scenes with LED illumination. With a wide-angle lens and native Jetson compatibility, it’s an ideal camera for AI vision, robotics, and outdoor perception systems demanding both stability and image fidelity.
Robotics and autonomous navigation
Smart traffic systems and ADAS prototypes
Industrial and warehouse automation
Drone vision and environmental monitoring
Embedded AI projects on Jetson Orin Nano/NX
▶ 120 dB High Dynamic Range (HDR)
Powered by Sony’s ISX031, this camera achieves a remarkable 120 dB HDR, capturing fine details in scenes with strong contrast — from bright outdoor sunlight to shaded areas. Ideal for autonomous systems that must see clearly under rapidly changing light.
▶ Built-in Image Signal Processor (ISP)
The integrated ISP handles real-time image optimization — including auto exposure, white balance, tone mapping, and noise reduction — reducing host workload and ensuring consistent image quality across applications.
▶ LED Flicker Mitigation (LFM)
With advanced flicker suppression, the ISX031 ensures stable, artifact-free imaging under LED or strobe light sources common in industrial, traffic, and warehouse environments.
▶ Wide-Angle Lens for Expanded Coverage
A factory-calibrated wide-angle lens provides a broad field of view, enabling greater spatial awareness and scene coverage for robotics, vehicles, or AI perception systems.
▶ Seamless Integration with Jetson Orin Nano/NX
Optimized for NVIDIA Jetson Orin Nano and NX platforms through the MIPI CSI-2 interface, offering high data throughput, low latency, and full compatibility with NVIDIA’s vision frameworks.
