Arducam 2.8-12mm Varifocal C-Mount Lens for Raspberry Pi HQ Camera, with C-CS Adapter
Arducam C-Mount Lens for Raspberry Pi High Quality Camera, 8mm Focal Length with Manual Focus and Adjustable Aperture
Arducam 4-12mm Varifocal C-Mount Lens for Raspberry Pi HQ Camera, with C-CS Adapter
LN048
  • A Better Option: Adapt the CS-Mount of the Raspberry Pi High Quality Camera to the access compact varifocal lens, C-CS adapter is included.
  • Multiple Adjustment: 4-12mm adjustable focal length with manual focus ring and aperture ring, help you get clear image in different focus distance.
  • Field of View (FOV): 87.2°(H)-39°(H), 80°(H)-32°(H) on 1/2.3″ IMX477 High Quality Camera
  • Other Specs – 1/2″ Lens Optical Format, F1: F16, Dimension: Φ33×43mm, Weight: 67.5g
$54.99
In order to meet the new demands of the lens to work with Raspberry Pi High Quality Camera, Arducam selected and tested a wide range of lenses on your Rpi HQ cameras. It's now much easier for you to get the best lens you'll need, and we will keep the lens list growing in the near future. It is a better option to adapt the CS-Mount of the Raspberry Pi High Quality Camera to the access compact varifocal lens with a C-CS adapter is included.
Lens Specification
  • Model No: C2004ZM12
  • Optical Format: 1/2"
  • Focal Length: 4 ~ 12mm
  • Aperture: F1:1.6
  • Field of View (FOV): 87.2°(H)-39°(H), 80°(H)-32°(H) on 1/2.3" IMX477 High Quality Camera
  • Focus Type: manual
  • Mount: C mount
  • Back Focal Length: 17.53mm
  • MOD: 0.2m
  • Dimension: Φ33×43mm
  • Weight: 67.5g
  • 1pcs 1/2" C-Mount 4~12mm varifocal lens for Raspberry Pi
You can purchase this item from Arducam distributors.
