The NoIR version of Arducam B0033 mini camera module for Raspberry Pi. This 5MP camera is natively compatible with the official Raspberry Pi camera modules and motherboards. It can be served as a night vision camera with external light sources like IR LED illuminators. It can also work on libcamera commands and python scripts as you would expect for a new project or drop-in replacement.
| Sensor | Omnivision OV5647 sensor |
| Sensor size | 1/4” (OV5647) |
| Resolution | 5MP 2592×1944 |
| Video | 1080p 30 fps, 720p 60fps, 480p 90fps |
| Field of View (FOV) | 54°(H), 41°(V) |
| Focus Type | Fixed Focus |
| Focus Length | 3.60mm |
| Focus Distance | 1 m to infinity |
| Full-frame SLR lens equivalent | 35 mm |
| IR Sensitivity | NoIR filter, sensitive to IR |
| Dimension | 25×24 mm |
| Peak Current | 300mA |
User Guide. pdf
The Pi NoIR is a Raspberry Pi camera module with no Infrared filter for night time and low light photography using an Infrared light. Useful for wildlife research, science projects, night time security or making artistic photo’s. The Raspberry Pi camera module has been used for many things such as a security camera, for time […]
