2MP Global Shutter OV2311 Mono Camera Modules Pivariety(NoIR ), compatible with Raspberry Pi ISP and Gstreamer Plugin-Arducam
Arducam 2MP Global Shutter OG02B10 Color Camera Modules Pivariety
Arducam Full HD Color Global Shutter Camera for Raspberry Pi, 2.3MP AR0234 Wide Angle Pivariety Camera Module
B0353
  • Low Power Consumption: Minimize active illumination power and reduce the system power requirements
  • More Applications: Gaze and eye-tracking capabilities, 3D image, depth sensing, etc.
  • Color Global Shutter: Based on 2MP AR0234 Color Global Shutter sensor
  • Piavriety Solutions: Arducam Pivariety camera solution for this camera
  • Easy to Setup: Connected directly to RPi’s CSI-2 camera interface without additional hardware
  • External Trigger Function: This function is used to capture the image and helps in synchronized streaming by connecting two or multiple cameras
$109.99
Arducam Pivariety is a Raspberry Pi camera solution to take the advantage of using its hardware ISP functions. Pivariety camera modules make users get better performance and a wider variety of camera, lens options. In other words, Pivariety breakthrough the limitations of the closed-source official supported camera driver and camera modules (V1/V2/HQ).
Pivariety made it possible to be well-tuned ISP with Auto Exposure, Auto White Balance, Auto Gain Control, Lens Shading Correction, etc.
This Pivariety AR0234 Color Global Shutter Camera is migrated Raspberry Pi Cameras, which eliminate rolling shutter artifacts to shoot high-speed moving objects in color sharp images.
  • Drones
  • 3D imaging
  • Machine vision
  • Industrial automation, etc.
  • Based on AR0234 Color Global Shutter Sensor: 2.3MP AR0234 global shutter color sensor, maximum frame rate up to 60fps.
  • Wide Angle: 90 deg (D) wide view angle
  • Gstreamer is supported with this camera
  • Support libcamera apps for the ISP processing image and official V4L2 apps
  • Compatible with all libcamera-based apps maintained by the RPi foundation
Camera Sensor Color Global Shutter AR0234
Pixel Size 3 μm x 3 μm
Active Array Size 1920 x 1200, 2.3MP
Optical Size 1/2.6 inch
IR Sensitive Integral IR-cut filter, visible light only
ISP Output Format Image: JPG, YUV420, RAW, DNG/Video: MJPEG, H.264
Camera Size 38mm x 38 mm
Output Format RAW10
Interface Type 2-Lane MIPI
Frame Rates 1920x1200@60fps, 1920x1080@60fps, 1280x720@120fps
Effective Focal Length 3.6mm
FOV on 1/4” RPi Camera 90°(D)x80°(H)x55°(V)
F/NO 3.0
Lens Mount M12
  • 1 x Arducam 2.3MP AR0234 ISP Camera Module
  • 1 x 150mm 15-22 pin FPC cable
  • 1 x 150mm 22-22 pin FPC cable
  • Arducam Pivariety cacmera can only work with libcamera, does NOT support Raspistill or Raspivid
  • V412 tools are supported, but only RAW format images can be obtained, without ISP support
  • The lens on this camera is not interchangeable, if you need to replace the lens, please contact sales in advance!
    Raspberry Pi 5
