Arducam OV9281 1MP Global Shutter NoIR Camera Module for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Time of Flight Camera for Raspberry Pi and NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam 2MP OV2311 Global Shutter M12 Mount NoIR Mono Camera Modules for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
B0221
  • Sensor: Global Shutter 2MP OV2311 Monochrome Image Sensor. Max resolution:1600×1300
  • Replaceable Lens: The lens on this camera is not interchangeable, if you need to replace the lens, please contact sales in advance!
  • V4L2 Framework: Support standard V4L2 framework, Video Nodes and Controls (Exposure, Gain and depending on camera parameters)
  • Support OpenCV Friendly and Provides Source Code Demonstration
  • The lens on this camera is not interchangeable, if you need to replace the lens, please contact sales in advance!
$109.99
As part of Project Jetvariety, which allows any camera modules to be connected to the high-speed CSI-2 connector on the Jetson Board. Arducam released this 2MP OV2311 Global shutter camera module, and it can be connected directly to Jetson Board’s CSI-2 camera interface without additional hardware.
Based on 1/2.9-inch Omnivision OV2311 image sensor which adopts OmniPixel3-GS™ technology, it provides full-frame, sub-sampled, and windowed 8/10-bit MIPI images, and capable of operating at up to 60fps in full resolution at 2-lane MIPI bus with complete user control over image quality.
Due to the sensor's high resolution, the OV2311 offers exceptionally accurate gaze- and eye-tracking capabilities, and it achieves high near-infrared quantum efficiency to minimize active illumination power and reduce the system power requirements.
Currently, NVIDIA official has released the NVIDIA Jetson Orin series developer board. Based on it, we have also adapted Arducam Jetvariety camera into NVIDIA Jetson Orin NX kernel.
Note:
  • This camera is released for the official NVIDIA® Jetson™ Developer Kit, and it does not guarantee to support other third-party boards.
  • Due to the hardware limitations of the NVIDIA Jetson platform, this product does not support ISP functionality. If a pre-tuned ISP solution is required, please refer to Arducam xISP series or Arducam TrueSight Series
  • ⚠️ KERNEL CAMERA DRIVER USED
    Sensors
    • Sensor: Global Shutter OV2311 Monochrome
    • Pixel size: 3 µm x 3 µm
    • Active array size: 1600 x 1300
    • Optical Format size: 1/2.9"
    • Maximum image transfer rate: 1600 x 1300: 60 fps
    • Support for image sizes: 1600 x 1300, 1280 x 720, 640 x 480
    • Input clock frequency: 6~27 MHz
    • Max S/N ratio: 37.4 dB
    • Dynamic range: 68 dB
    • Lens Thread: M12 x 0.5P
    • Lens Field of View(FoV): 83°(H)
    • IR Sensitivity: without IR Filter, IR sensitive
    Camera Module
    • Output interface: 2-lane MIPI
    • Output formats: RAW 8/10 bit
    • Resolution & Frame Rate: 1600x1300@60fps, 1600x1080@80fps, 1280x720@120fps
    • Resolution&Frame Rate(NVIDIA Orin NX): 1600x1300@60fps,1600x1080@80fps,1280x720@120fps
    • Minimum exposure time: 1 row period (11.3us at the resolution of 1600x1300 on Jetson Board.)
    Driver Features
    • Support Gray, Y10, Y16
    • Support standard V4L2 framework, Video Nodes and Controls (Exposure, Gain and depending on camera parameters)
    • Support External Trigger Global Shutter Camera
    • Support Single Line Driver Installation Command
    • Only support the camera interface close to the NVIDIA Jetson carrier board power interface.
    Applications:
    • DSC
    • Machine Vision
    • Robotics
    • Face Recognition
    • Note on supported Nvidia Jetson Boards and Jetpack versions, please refer to Supported JetPack Version for Different NVIDIA Jetson Platforms to ensure compatibility.
    • The camera is only supported on the official NVIDIA Jetson I/O carrier board.
    • It only supports connecting the camera to the CSI interface near the NVIDIA Jetson carrier board power connector.
    • Due to the hardware limitations of the NVIDIA Jetson platform, this product does not support ISP functionality. If a pre-tuned ISP solution is required, please refer to Arducam xISP series or Arducam TrueSight Series.
    • For connection on the NVIDIA Jetson AGX Orin platform, you will need an additional MIPI adapter board. You can contact Arducam sales to obtain one if needed.
    Jetvariety – MIPI Camera Modules for Jetson Nano/Xavier NX
    Posted: March 25, 2020
    Jetson Nano’s MIPI interface and MIPI connectors The Jetson Nano Developer Kit consists of two parts: The Computer on a Module (CoM), and the carrier board. The CoM supports high-speed MIPI interface, which is now a must-have for embedded vision applications. The carrier board of the Jetson Nano developer kit exposes the MIPI interface in […]
    arducam jetson nano camera general purpose solution blog thumbnail 215 187
    Introducing Project Jetvariety – Increase the Jetson Nano Camera Variety Today we are proud to introduce the Project Jetvariety (short for Jetson variety), which aims to quickly increase the variety of Jetson Nano cameras with our proprietary general-purpose camera solution. The Jetson Nano and Xavier NX only have official driver support of the Raspberry Pi […]
    16 comments
