[Discontinued] Arducam 2MP Global Shutter OG02B10 Color Camera Modules with M12 lens for Raspberry Pi
[Discontinued] Arducam 8MP Pan Tilt Zoom PTZ Camera with Base for Raspberry Pi 4/3B+/3 and NVIDIA® Jetson Nano/Xavier NX/AGX Orin/Orin Nano/Orin NX
[Discontinued] Arducam 2MP Global Shutter OG02B10 Color Camera Modules with M12 lens for Jetson Nano
B0344
Discontinued, check alternative item B0429.
$109.99
As part of Project Jetvariety, which allows any camera modules to be connected to the high-speed CSI-2 connector on the Jetson Nano. Arducam released this 2MP OG02B10 Global shutter camera module, and it can be connected directly to Jetson Nano’s CSI-2 camera interface without additional hardware.
Based on 1/2.9-inch Omnivision OG02B10 image sensor which adopts OmniPixel3-GS™ technology, it provides full-frame, sub-sampled, and windowed 8/10-bit MIPI images, and capable of operating at up to 60fps in full resolution at 2-lane MIPI bus with complete user control over image quality.
Due to the sensor's high resolution, the OG02B10 offers exceptionally accurate gaze- and eye-tracking capabilities, and it achieves high near-infrared quantum efficiency to minimize active illumination power and reduce the system power requirements.
⚠️ KERNEL CAMERA DRIVER USED
Sensors
  • Sensor: Global Shutter OG02B10 Color
  • Pixel size: 3 µm x 3 µm
  • Active array size: 1600 x 1300
  • Optical Format size: 1/2.9"
  • Maximum image transfer rate: 1600 x 1300: 60 fps
  • Support for image sizes: 1600 x 1300, 1280 x 720, 640 x 480
  • Input clock frequency: 6~27 MHz
  • Max S/N ratio: 37.4 dB
  • Dynamic range: 68 dB
  • Lens Thread: M12 x 0.5P
  • Lens Field of View(FoV): 83°(H)
  • IR Sensitivity: with IR Filter, sensitive to visible light
Camera Module
  • Output interface: 2-lane MIPI
  • Output formats: RAW 8/10 bit
  • Minimum exposure time: 1 row period (11.3us at the resolution of 1600x1300 on Jetson Nano.)
Driver Features
  • Support Gray, Y10, Y16
  • Support standard V4L2 framework, Video Nodes and Controls (Exposure, Gain and depending on camera parameters)
  • Support External Trigger Global Shutter Camera
  • Support Single Line Driver Installation Command
  • Support OpenCV Friendly and Provides Source Code Demonstration
  • Support Dual Camera Synchronzation
Applications:
  • DSC
  • Machine Vision
  • Robotics
  • Face Recognition
  • 1pcs Arducam 2MP OG02B10 Color Camera Module
  • 1pcs Arducam Adapter Board for Jetson Nano
  • 1pcs 150mm 15pin 1.0mm FPC cable
  • 1pcs 73mm 15pin 1.0mm to 22pin 0.5mm pitch FPC cable
  • Acrylic case for the camera module
