The IMX462 Day&Night USB Cam is the latest addition to Arducam's USB 2.0 camera series. This cutting-edge USB camera features a Starvis CMOS, the IMX462, paired with a lager aperture M12 lens, ensuring optimal light intake for flawless night vision capabilities. With six 940nm infrared LEDs and a 940@650nm double-pass filter on the lens, this camera effortlessly transitions between day and night modes, adapting to changing light conditions with the help of a photosensitive resistor.
Under low-light scenarios, the camera activates its infrared LEDs, offering black-and-white night vision at an impressive range of 3 meters. During daylight, it seamlessly captures vibrant color images using visible light around 650 nm.
The Arducam USB 2.0 camera is designed for user convenience, featuring a plug-and-play functionality that requires no intricate installations or driver downloads. Whether you're a technology enthusiast or a seasoned professional, this USB camera ensures a hassle-free experience for capturing moments and engaging in seamless video conferences. Upgrade your imaging capabilities with the versatility and user-friendly design of the Arducam USB 2.0 camera.
| Image Sensor | |
| Sensor | IMX462 |
| Still Resolution | 2 Megapixels |
| Color Filter Type | Color |
| Shutter Type | Rolling |
| Optical Size | 1/2.8" |
| Output Format | MJPG/YUY2/H.264 |
| Pixel Size | 2.9 µm x 2.9 µm |
| Sensor Active Area | 1920(H)×1080(V) |
| Frame Rate | YUY2: 30fps320×240, 640×480; MJPG: 30fps@320×240,640×480,1280×720,1920×1080, H264: 30fps@1920×1080,1280×720, 640×480, 640×360 |
| Lens | |
| Focus Type | Manual Focus |
| FOV | 95°(D)×83°(H)×67°(V) |
| Lens Mount | M12 Mount |
| F.NO | F1.6 |
| E.F.L | 4.3mm |
| IR Sensitivity | Dual Bandpass Filter Visible + 940nm NIR |
| Default Focus Distance | 2m-∞ |
| USB Interface | |
| Interface | USB 2.0 Device |
| Connector | B4B-ZR |
| Power Requirements | Max: 1.2W |
| Camera Board Size | 32×32mm(Hole Pitch: 28×28mm) |
| Audio | Single Microphone |
| Recommend Sample Application | Amcap for Windows |
| UVC Controls | Brightness, Contrast, Hue, Saturation, Sharpness, Gamma, White Balance(Auto/Manual), Backlight Contrast, Gain, Exposure(Auto/Manual). |
