8MP 1080P USB Camera Module, 1/4
8MP 1080P USB Camera Module, 1/4" CMOS IMX219 Mini UVC USB2.0 Webcam
Arducam 5MP OG05B1B Mono Global Shutter USB 3.0 Camera
Arducam 1080P Day/Night Vision USB Camera, 2MP Infrared Webcam with Automatic IR-Cut Switching and IR LEDs
B0506
  • Full HD 1080P USB Camera: Smooth 30fps@1080p video with 1/2.7″ OV2710 CMOS sensor.
  • Day/Night Vision: 6pcs 850nm IR LEDs & photoresistor for clear imagery in low light.
  • Wide-Angle Lens: 105° starlight lens with F1.6 aperture captures intricate details.
  • Automatic IR-Cut Switching: Seamless day-night transitions for enhanced vision.
  • Plug-and-Play: UVC compliant, connect to PC, laptop, Android, or Raspberry Pi for versatile surveillance.
$34.99
Introducing the latest Arducam USB2.0 camera, featuring a 1/2.7" CMOS OV2710 sensor for seamless 30fps@1080P video capture. With its exceptional day and night performance, this camera ensures clear and sharp imagery around the clock.
Equipped with a built-in IR LED and photoresistor, it seamlessly transitions between day and night modes, automatically activating IR light for optimal low-light performance. Coupled with its starlight-rated wide-angle M12 lens, it maximizes light intake for superior surveillance capabilities.
Forget about driver installations – simply connect via USB to your PC, laptop, Android device, or Raspberry Pi. Versatile and adaptable, this mini USB camera is perfect for home surveillance, 3D printer monitoring, video conferencing, dashcam, and more.
  • Animal Monitoring
  • Video Surveillance
  • 3D Scanning and Metrology
  • Home Surveillance System
  • Dashcam
  • Full HD 1080P: Based on the 1/2.7" OV2710 CMOS, delivering smooth 30fps@1080p video recording for unparalleled clarity and detail.
  • Day/Night Vision USB Cam: Equipped with a photoresistor and 6pcs 850nm IR LEDs, experience superior visibility even in low-light scenarios, ensuring sharp and vivid imagery round the clock.
  • Expansive Perspective with Wide-Angle Lens: Enjoy maximized light intake with the 105°(D) wide-angle starlight lens boasting an F1.6, enabling remarkable sensitivity and intricate detail capture across the entire frame.
  • Seamless Day-to-Night Transitions: Effortlessly adapt to changing light conditions with automatic IR-cut switching. Experience enhanced night vision without manual adjustments as the camera seamlessly activates its 850nm IR LEDs for unparalleled clarity.
  • Hassle-Free Setup: Enjoy instant usability with plug-and-play convenience. Compliant with the UVC protocol, no additional drivers are needed. Simply connect via USB to your preferred device for versatile applications including security monitoring, home surveillance, dashcam, and more.
Sensor OV2710
Still Resolution 2 Megapixels
Optical Size 1/2.7"
Output Format MJPG/YUY2
Pixel Size 3 µm x 3 µm
Sensor Active Area 1920(H)×1080(V)
Frame Rate MJPG: 30fps@320*240, 352*288, 640*480, 800*600, 1024*768, 1280*720, 1280*960, 1280*1024, 1920*1080
YUY2: 30fps@320*240,352*288; 15fps@640*480; 20fps@800*600; 10fps@1024*768, 1280*720; 5fps@1280*960,1280*1024,1920*1080
Focus Type Manual
FoV 105°(D) × 92°(H) × 76°(V)
Lens Mount M12 (S-mount)
F.NO F1.6±10%
E.F.L 4.3±5%
IR Sensitivity Integral IR-Cut Filter
(Only sensitive to visible light during the day, sensitive to IR at night with 850 IR LEDs on)
Default Focus Range 2m-∞
Interface USB 2.0 Device
Connector B4B-ZR
Power Requirements Max: 2.0W
Camera Board Size 38×38 mm
Audio Single Microphone
Supported OS Windows, Linux, Android and MAC OS
Recommend Sample Application Amcap for Windows
UVC Controls Brightness, Hue, Contrast, Saturation, Sharpness, Gamma, White Balance (Manual/Auto), Gain, Backlight Comp, Exposure (Manual/Auto)
  • 1 x OV2710 USB2.0 Camera
  • 1 x 1m USB 2.0 Cable
