Arducam 2MP IMX462 Day and IR Night Vision USB Camera with Metal Case
5MP UVC Camera Module with Wide Angle M12 Lens and Metal Housing for Windows, Linux, Android, and Mac OS
Arducam 1080P Low Light Low Distortion USB Camera Module with Microphone
B0468
$39.99
This IMX323 USB camera boasts a maximum resolution of 2 megapixels utilizing the advanced IMX323 image sensor. With a maximum still resolution of 1920*1080, users can capture detailed images. Moreover, the camera's frame rate can reach up to 30fps@1080P, ensuring smooth and fluid video capture.
With its low distortion M12 Lens offering a field of view 83° DFoV, this camera captures stunningly accurate images.
Arducam USB camera stands out with its user-friendly plug-and-play functionality. Offering compatibility with Windows, Linux, Mac OS, and Android, no additional drivers are needed, simplifying the setup process.
  • Video conference
  • Dash cam
  • Monitoring 3D printer
  • Robot and machine vision
  • HD Resolution and Low Light: Based on 2MP IMX323 sensor, minimum illumination 0.01 [email protected]
  • Low Distortion: with 83°(D) Low-Distortion (<1%) M12 Lens
  • Capture Video with Audio: H.264/MJPG: 30fps@1080p; YUYV: 30fps@640*480
  • Plug&Play: UVC-compliant, no extra drivers needed
  • Applications: Home surveillance, day-night vision, dashcam, machine vision
Sensor Features
Sensor IMX323
Still Resolution 2 Megapixels
Optical Size 1/2.9"
Output Format MJPG/YUYV/H.264
Pixel Size 2.8μmx 2.8μm
Sensor Active Area 1936(H)*1097(V)
Frame Rate MJPG: 1920*1080@30fps, 1280*720@30fps, 800*600, 640*360, 640*480, 352*288,320*240@30fps
YUYV: 15fps@800*600, 30fps@320*240/352*288/640*360/640*480
H.264: 30fps@ 1920*1080, 1280*720, 800*600, 640*360, 640*480, 352*288,320*240
FOV 83°(D)×71°(H)×55°(V)
E.F.L 4mm
Distortion <1%
Interface USB 2.0 device
Connector B4B-ZR
Operating Temp. 0°C to 70°C
Power Requirements Max: 1.25W
Camera Board Size 38*38 mm (Hole Pitch: 34mmx34mm, 28mmx28mm)
Audio Single Microphone
Supported OS Windows, Linux, Android and MAC OS
Sample Application AMCap
UVC Controls Brightness, Contrast, Hue, Sharpness, Saturation, Gama, Gain, White Balance(Manual and Auto), Backlight contrast, Exposure(Manual and Auto)
  • 1 x 1080P USB Camera Module with Lens
  • 1 x 1m USB 2.0 Cable
  • 1 x Quick Guide Start
