Arducam Full HD Color Global Shutter Camera for Raspberry Pi, 2.3MP AR0234 Wide Angle Pivariety Camera Module
Arducam Ultra Low Light 2MP IMX462 STARVIS Camera, 1080P HD Wide Angle Pivariety Camera Module for Raspberry Pi
Arducam 2MP Global Shutter OG02B10 Color Camera Modules Pivariety
B0348
  • Low Power Consumption: Minimize active illumination power and reduce the system power requirements.
  • More Applications: Gaze and eye-tracking capabilities, 3D image, depth sensing, etc.
  • Color Global Shutter: Based on 2MP OG02B10 Color Global Shutter sensor
  • Piavriety Solutions: Arducam Pivariety camera solution for this camera
  • Easy to Setup: Connected directly to RPi’s CSI-2 camera interface without additional hardware.
$109.99
Arducam Pivariety is a Raspberry Pi camera solution to take the advantage of using its hardware ISP functions. For a long time, Raspberry Pi users are limited to use the closed-source official supported camera driver and camera modules (V1/V2/HQ). Now Arducam made it possible to provide well-tuned ISP for Pivariety camera modules with Auto Exposure, Auto White Balance, Auto Gain Control, Lens Shading Correction, etc.
Pivariety OG02B10 Color Global Shutter Camera eliminates rolling shutter artifacts to better capture the fast-moving object. Pivariety OG02B10 Camera uses the libcamera framework and the way to access the camera is libcamera SDK(for C++)/libcamera-still/libcamera-vid/Gstreamer. In addition, Pivariety OG02B10 Global Shutter Camera having an external trigger function, which is used to capture the image and helps in synchronized streaming by connecting two or multiple cameras. In production applications (such as assembly line production), the external trigger mode can synchronize the camera with other events.
  • Drones
  • 3D imaging
  • Machine vision
  • Industrial automation, etc.
Camera Sensor Color Global Shutter OG02B10
Pixel Size 3 μm x 3 μm
Active Array Size 1600 x 1300
Optical Size 1/2.9 inch
Frame Rates 1600×1300@60fps; 1600×1080@80fps; 1280×720@120fps
IR Sensitive Integral IR filter, visible light only
Camera Board Size 38mm x 38mm
Output Format RAW10, RAW8
ISP Output Format Image: JPG, YUV420, RAW, DNG, Video: MJPEG, H.264
Effective Focal Length 2.8mm
FOV on 1/4” RPi Camera 110° (H)
F/NO 2.8
Lens Mount M12
Interface Type 2-Lane MIPI
    Raspberry Pi 5 √ √
  • 1 x Arducam 2MP OG02B10 Color Camera Module
  • 1 x Arducam adapter Board
  • 1 x 150mm 15-22pin FPC cable
  • 1 x 150mm 22-22pin FPC cable
  • Pivariety OG02B10 2MP Color Global Shutter Camera Module
  • Access OG02B10 2MP Color Global Shutter Camera using external trigger snapshot mode
  • 3D Drawing.STEP
  • External Trigger Mode for Global Shutter Camera on Raspberry Pi
    1.Introduction Arducam Pivariety is a Raspberry Pi camera solution to take the advantage of using its hardware ISP functions. Using Arducam Pivariety camera modules, users can get better performance and a wider variety of camera, lens options. For a long time, Raspberry Pi users are limited to use the closed-source official supported camera driver and […]
    Pivariety OG02B10 Global Shutter Camera having an external trigger function, which is used to capture the image and helps in synchronized streaming by connecting two or multiple cameras. In production applications (such as assembly line production), the external trigger mode can easily synchronize the camera with other devices. In addition, the sensor (OG02B10) enables the […]
