The latest addition to Arducam's lineup is the AR2020 USB 3.0 camera. Boasting a 20MP 1/1.8" color CMOS, this camera delivers stunning still images with a maximum resolution of 5120(H)*3840(V). Its exceptional low-light capabilities make it perfect for a variety of night vision applications, including security surveillance, wildlife monitoring, iris recognition, and more.
Equipped with a high-quality 95-degree diagonal starlight M12 lens, this camera ensures crystal-clear imaging across diverse environments. Plus, it incorporates Arducam's advanced ISP technology, including de-bayer, gamma correction, black level compensation, auto exposure, color correction matrix, and RGB to YUV conversion. With a flexible and adjustable frame rate of up to 1280*960@90fps, it offers versatility to suit any project's needs.
| Image Sensor | |
| Sensor | AR2020 |
| Still Resolution | 20 MP |
| Color Filter Type | Color |
| Shutter Type | Rolling Shutter |
| Optical Size | 1/1.8" |
| Output Format | YUY2 |
| Pixel Size | 1.4× 1.4 μm |
| Sensor Active Area | 5120(H) × 3840(V) |
| Frame Rate (USB 3.0) | 5120x3840@8fps, 3840x2160@20fps, 2560x1920@30fps, 1920x1080@60fps, 1280x960@90fps |
| Frame Rate (USB 2.0) | 1280x960@10fps | Lens |
| Focus Type | Fixed Focus |
| Default Focus Range | 3m-∞ |
| FOV | 95°(D) × 82°(H) × 66°(V) |
| Lens Mount | M12 (S-mount) |
| F.NO | F1.65±10% |
| E.F.L | 4.9±5% |
| USB Interface | |
| Power Requirements | Max: 1.57W , Min: 0.8W |
| UVC Controls | Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Exposure (Manual/Auto) |
