This IMX519 USB 3.0 camera boasts a maximum resolution of 16 megapixels utilizing the advanced IMX519 image sensor. With a maximum still resolution of 4656*3496, users can capture incredibly detailed images. Moreover, the camera's frame rate can reach up to 80fps@720P, ensuring smooth and fluid video capture.
With its high quality auto-focus lens offering a field of view 78°(D), this camera captures stunningly accurate images.
| Image Sensor | |
| Sensor | IMX519 |
| Still Resolution | 16 Megapixels |
| Color Filter Type | Color |
| Shutter Type | Rolling |
| Optical Size | 1/2.53" |
| Output Format | YUY2 |
| Pixel Size | 1.22 µm x 1.22 µm |
| Sensor Active Area | 4656(H)×3496(V) |
| Frame Rate (USB 3.0) | 1280*720@80fps, 1920*1080@50fps, 2320*1748@25fps, 3840*2160@15fps, 4656*3496@8fps |
| Frame Rate (USB 2.0) | 1280*720@10fps |
| Lens | |
| Focus Type | Auto Focus |
| FOV | 78°(D)×65°(H)×51(V) |
| Lens Mount | Stock Lens |
| F.NO | F1.75 |
| E.F.L | 4.28mm |
| Default Focus Range | 10cm-∞ |
| USB Interface | |
| Power Requirements | Max: 1.48W , Min: 0.77W |
| UVC Controls | Brightness, Contrast, Saturation, White Balance(Manual and Auto), Gain, Exposure(Manual and Auto), Focus(Auto/Manual) |
