Arducam RoAD IMX900 3.2MP Global Shutter USB3 Wide Angle Camera for Robotics
Arducam 1.58MP IMX296 Mono Global Shutter USB 3.0 Camera Module
Arducam 2.3MP Color Global Shutter USB3 UVC Camera Module with Onboard ISP for Robotics and Machine Vision
B0610
  • [Global Shutter] Features the selected global shutter sensor for imaging of fast-moving objects.
  • [High Frame Rate] Delivers 1920x1200@100fps streaming for latency-sensitive applications
  • [Plug & Play] USB3.0 UVC, out of box use is guaranteed.
  • [Onboard ISP] Contrast, Saturation, Auto White Balance, Gain, Exposure (Manual/Auto)
  • [High Resolution] 2.3MP (1920×1200) resolution delivers crisp detail for precision machine vision tasks
SAMPLE PRICE
$139.99
VOLUME PRICE
This plug-and-play camera module adopts global shutter image sensor (2.3MP, 1920×1200) with USB3.0 UVC compliance, ensuring zero-driver compatibility across Windows/Linux platforms. Pre-calibrated with M12 wide-angle lenses for wider field of view and precision alignment, the kit delivers motion-blur-free data for robotics navigation or other precision measurement. The onboard ISP enables real-time tuning of exposure, gain, and auto white balance, while the USB3.0 interface (5Gbps bandwidth) guarantees low-latency streaming—ideal for rapid prototyping or scalable deployment in machine vision applications.
    Industrial & Robotics
  • [Humanoid] Various of humanoid robotics applications
  • [Machine Vision Inspection] Detecting defects, labels, or alignment in manufacturing lines
  • [Robotic Navigation] Visual guidance for mobile robots and AGVs (Automated Guided Vehicles)
  • [Barcode/QR Code Scanning] High-speed decoding in logistics and packaging systems
  • [Pick-and-Place Systems] Real-time object tracking for automation arms
  • [Other Robotics related applications]
  • Global Shutter Technology: Designed for capturing high-quality images of fast-moving objects, ensuring clarity and precision in dynamic environments.
  • Pre-Calibrated M12 Lens: Equipped with an M12 wide-angle lens, the camera is ready for various application scenarios. Customizable alternative M12 Lenses are available.
  • Plug & Play Functionality: USB3.0 UVC Support. Ensures out-of-the-box usability, allowing for easy integration without extensive setup.
  • Onboard Image Signal Processing (ISP): Features adjustments for contrast, saturation, auto white balance, gain, and exposure (both manual and automatic) to optimize image quality.
  • High-Res & Frame Rate: 2.3MP(1920x1080) High resolution among Global shutter cameras, the camera delivers 1920x1200@100fps streaming for latency-sensitive applications
  • Long Term Supply & Long Term Support: Arducam offers long-term support for the deployment in proof of concept (PoC) or mass production. Not just production, but also with services.
Sensor 2.3MP Color Image Sensor
Shutter Type Global Shutter
Optical Size 1/2.6"
Output Format MJPG/YUYV
Pixel Size 3 µm x 3 µm
Frame Rate (USB 3.0) MJPG: 1920x1200@100fps, 1920x1080@120fps; 1280x720@120fps, 640x480@100fps; YUYV: 1920x1200@60fps, 1920x1080@60fps; 1280x720@120fps, 640x480@100fps;
Frame Rate (USB 2.0) MJPG: 640x480@10fps
FOV(DxHxV) 110°(D)×98°(H)×75°(V)
F.NO F2.4±5%
E.F.L 2.8±5% mm
Default Focus Range 0.3m to INF
TV-Distortion <-1.3%
UVC Controls Contrast, Saturation, White Balance (Auto/Manual), Gamma, Gain, Sharpness, Backlight Compensation, Exposure (Manual/Auto)
Power Requirements Max: 2W
Camera Board Size 34mm x 34mm
Overall Weight (Net) 41.8g
Certification RoHS, CE
  • 1 x Arducam 2.3MP Color Global Shutter USB3 UVC Camera Module
  • 1 x 1m USB3 Type-C cable
  • This camera module supports the development of external trigger mode, frame rate, ROI, etc.. If you need these functions, please contact arducam for customization.
