Arducam 2.3MP Color Global Shutter USB3 UVC Camera Module with Onboard ISP for Robotics and Machine Vision
Arducam 1.58MP IMX296 Mono Global Shutter USB 3.0 Camera Module
B0641
  • [Easy use] Plug and play with 44fps High-speed USB3 Connectivity.
  • [Premium sensor] Based on 1.58MP IMX296 mono global shutter sensor, maximum still resolution of 1456*1088.
  • [ISP] Proprietary on-board ISP advances image enhancement.
  • [Robust housing] Metal case for sleek and robust use experience.
  • [Selected lens] Professional 6mm EFL CS Mount Lens for Precision focus.
$219.99
Arducam's USB 3.0 camera series presents the IMX296 Mono global shutter model. With a 1.58MP CMOS sensor and a maximum still resolution of 1456x1088, this camera produces uncompressed, high-quality images in YUYV format. The on-board ISP optimizes image quality, while the global shutter, USB 3.0 connectivity, and a rapid 44fps frame rate ensure seamless video. Equipped with a 6mm CS lens boasting a 60° diagonal field of view, it delivers accurate and detailed images for diverse applications.Arducam latest USB 3.0 camera stands out with its user-friendly plug-and-play functionality. Offering compatibility with Windows and Linux OSs, no additional drivers are needed, simplifying the setup process. Moreover, its backward compatibility with USB 2.0 host ports ensures flexibility and seamless connectivity.
  • Home Security System
  • Wildlife Photography
  • Unattended surveillance
  • Industrial Vision/Machine Vision
  • Automation, AI Project, etc.
  • Outstanding Imaging: Arducam's IMX296 USB3 camera boasts a 1.58MP mono global shutter sensor for exceptional clarity at 1456x1088 resolution.
  • High-Speed USB 3.0 Connectivity: Enjoy up to 44fps frame rate flexibility and global shutter functionality, ensuring artifact-free high-speed motion capture.
  • Equipped with a 6mm CS mount lens, this camera allows manual adjustment for sharp, clear images tailored to your needs.
  • Advanced Image Enhancement: On-board ISP with proprietary tech ensures top-tier image quality through de-Bayer, gamma, BLC, AE, AWB, CCM, and RGB2YUV processes.
  • Plug and Play: Seamless compatibility with Windows and Linux, plug-and-play functionality eliminates the need for additional drivers.
Sensor IMX296
Resolution 1.58 Megapixels
Chroma Monochrome
Shutter Type Global Shutter
Optical Format 1/2.9"
Pixel Size 3.45 µm x3.45 µm
Sensor Active Area 1456(H)×1088(V)
Sensor Image Area 5.023 mm x 3.788 mm (6.3mm diagonal)
Output Format YUYV
Resolution@fps (USB3.0) 1456x1088@44fps
Resolution@fps (USB2.0) 1456x1088@10fps
FOV 60°(D)×50°(H)×38°(V)
Lens Mount CS Mount
F.NO F1.2
E.F.L 6mm
IR Sensitivity NoIR, sensitive to IR Light
Default Focus Distance 200cm-INF
Distrotion <-0.1%
Weight 53g
USB Features
Recommend Imaging Applications PotPlayer for Windows, qv4l2 for Linux
UVC Controls Brightness, Contrast, Gain, Exposure (auto/manual)
Power Consumption Max: 1.89W
Overall Weight (Net) 86g
Overall Size 34x34 mm
Certification RoHS
  • 1 x Arducam 1.58MP IMX296 Mono Global Shutter USB3 UVC Camera Module
