This Arducam quadrascopic camera bundle incorporates four 1MP OV9281 global shutter cameras, and the cutting-edge MIPI stereo camera breakthrough from Arducam - The Arducam Camarray HAT. As the upgraded version of Arducam Synched Stereo Camarray HAT, the Camarray further pushes the multi-camera limits and doubles the interfacing capabilities to allow 4 synchronized MIPI camera modules to be interfaced to a single MIPI CSI-2 slot on prevailing single-board computers like Raspberry Pi, Jetson Board. Also, as the Camarray HAT releases, Arducam starts to support a variable baseline for stereo camera applications with some modified Arducam camera modules, such as those OV9281 ones included in this bundle. Since no shared camera board or clock-sharing soldering is required for the image sensors, you can kick off your prototyping for stereo camera applications and then decide the optimal baseline. This camera can only get four images. Arducam also accepts subsequent customizations for your stereo camera applications.
| Support Platform | Raspberry Pi and Jetson Board |
| Output/CSI-2 Speed | x1 CSI-2 2-lane Output Port/1.0 Gbps/Lane |
| ISP Support | Supported on Raspberry Pi, Not supported on Nvidia Jetson |
| External Trigger | Support |
| Aggregate mode | Full Spelling |
| Frame Rate(On Raspberry Pi) | RAW8: 5120x800@45fps, 5120x720@50fps, 2560x400@150fps; RAW10: 5120x800@35fps, 5120x720@40fps, 2560x400@110fps |
| Frame Rates(On NVIDIA Jetson)* | RAW8: 5120x800@45fps, 5120x720@50fps, 2560x400@150fps; RAW10: 5120x800@35fps, 5120x720@40fps, 2560x400@110fps |
| Image Sensor | Monochrome Global Shutter OV9281 |
| Pixel Size | 3 μm x 3 μm |
| Active Array Size | 1280 x 800 |
| Optical Size | 1/4 inch |
| Focusing Range | 30cm ~ INF |
| IR Sensitive | No IR filter, sensitive to IR |
| Camera Board Size | 40mm x 40mm |
| Camarray Hat Size | 65 x 55 mm |
| Optical Format | 1/2.7” |
| Distortion | <1% |
| Effective Focal Length | 2.8mm |
| FOV on 1/4” RPi Camera | 82°(D) x 70° (H) x 55°(V) |
| F/NO | 2.8 |
| Lens Mount | M12 |
| Lens Size | 14mm x 15.6mm |
| Lens Weight | 4g |
| Default Lens | Low distortion M12 lens (Part Number: M27280M07S) |
*:JetPack4.6/L4T32.6.1 on NVIDIA Jetson Board
Used on Raspberry Pi:
Introduction This Arducam quadrascopic camera bundle incorporates four 1MP OV9281 global shutter cameras, and the cutting-edge MIPI stereo camera breakthrough from Arducam – The Arducam Camarray HAT. At present, this product supports ISP image processing, and the OBISP driver can be used without an external ISP. As the upgraded version of Arducam Synched Stereo Camera […]
Used on NVIDIA Jetson:
/li>Introduction This Arducam quadrascopic camera bundle incorporates four 1MP OV9281 global shutter cameras, and the cutting-edge MIPI stereo camera breakthrough from Arducam – The Arducam Camarray HAT. As the upgraded version of Arducam Synched Stereo Camera HAT, the Camarray further pushes the multi-camera limits and doubles the interfacing capabilities to allow 4 synchronized MIPI camera […]
Arducam Camarray Solution Showcase:
[Tutorial] 4 Sync OV9281 Cameras on 1 Raspberry Pi
