Arducam Camera Module 3 delivers high-quality images with its 12MP Sony IMX708 image sensor and HDR mode for up to 3MP output. Equipped with a 75° DFOV autofocus Lens, PDAF, and 2D DPC, this module offers exceptional SNR.
The camera module is native to Raspberry Pi and compatible with Raspberry Pi OS and libcamera command. It is also compatible with Raspberry Pi 3, 4 A/B, and Zero.
Astrophotography
Surveillance cameras
FA cameras
Industrial/Agricultural cameras
Autonomous mobile robots, UGV/UAV, ADAS, etc.
Arducam Camera Module 3: Based on a back-illuminated stacked CMOS, 2-megapixel high-resolution Image Sensor IMX708 with HDR mode for up to the 3-megapixel output.
High-Quality Images: Capture high-quality images with a 75° DFOV autofocus lens and max resolution of 4608×2592.
Quick Autofocus: Phase Detection Autofocus (PDAF) delivers rapid autofocus, ensuring that you never miss a shot.
Native to Raspberry Pi: No additional driver is needed when using the camera on Raspberry Pi.
Platform Compatibility: Supports Raspberry Pi 3, 4 A/B, equipped with 15-22pin and 22-22pin FPC flexible cables. Supports application on Raspberry Pi Zero.
Raspberry Pi 5/4B/3B+/3/2/CM3/CM4/CM5/Zero W/Zero 2 W
Focus Type
Motorized
Focal Length
4.74 mm
F.NO
F1.8
Field of View(FOV)
75°(D)x66°(H)x41°(V)
Lens Mount
Camera Board Size
25 × 24mm
1 x IMX708 AF Camera Module
1 x15cm 15-15pin FPC cable
1 x15cm 15-22pin FPC cable
1 x Paper Quick Start Guide
This camera module is natively supported by Raspberry Pi. There is no need to install an additional driver for it. Just modify the config file to access it.
After receiving the package, please confirm whether the contents of the package are consistent with the description
