Arducam 2.3MP*2 AR0234 Color Global Shutter Synchronized Stereo Camera Bundle Kit for Raspberry Pi
Arducam 12MP*4 477P Quadrascopic Camera Bundle Kit for Raspberry Pi, NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam 12MP IMX708 Quad-Camera Kit, Wide Angle Stereo Synchronized Camera Module for Raspberry Pi
B0484
  • Multiplexing with High Res: Four x 12mp IMX708 cameras on one Pi.
  • Stereo Synchronized: Up to 4 cameras capturing at the same time.
  • Autofocus: AF/Manual/Continuous-AF out of the box.
  • Flexible Control: Single/Dual/Quad channel modes.
  • Variable Baseline Extension: Adopt Arducam Camarray adapter board, connect with flexible cable.
  • Four in One: Combine four cameras into one frame, each camera with a max resolution of 2304(H)x1296(V)
$199.99
This Arducam quadrascopic camera bundle incorporates four 12MP IMX708 autofocus cameras, and the cutting-edge MIPI stereo camera breakthrough from Arducam – The Arducam Camarray HAT.
With the new launch of Raspberry Pi Camera Module 3, we have adapted various camera solutions for it. Arducam Camarray Kit is one of them. Arducam Camarray further pushes the multi-camera limits and doubles the interfacing capabilities to allow 4 synchronized MIPI camera modules to be interfaced to a single MIPI CSI-2.
The separated cameras can be used with a variable baseline device and controlled through the computer control system to achieve rapid and dynamic interactive adjustment of the moving parts for human-like multi-degree-of-freedom stereo binocular vision. This kit is expanded based on IMX708, and its function is exactly the same as the official Camera Module 3 (such as pdaf focus, and HDR, etc.).
  • Stereo Vision
  • Panoramic Photography
  • Head, and eye tracking
  • 3D Reconstruction
  • Depth-related vision applications, etc.
  • Designed for Arducam IMX708 Wide Angle Camera Module 3, both video and photographs are available, and the clock is synchronized(accurate to the millisecond level).
  • Achieves full hardware-level frame synchronization for four cameras, eliminating the need for additional time-stamping schemes.
  • Four in One: Combines four cameras into a single frame, each operating at a 1/4 resolution (1152x648), resulting in maximum outputs of 4608x2592 for still images and 1920x1080 for video. Note that frame rates are halved compared to single-camera operation.
  • Default operation in quad-channel mode ensures simultaneous image and video capture. Also supports channel switching (Single/Dual/Quad) for versatility.
  • Exact V3 Function Match: Modified for compatibility with the IMX708 enabling shared I2C signals and clock while retaining original features such as PDAF and HDR.
  • Variable Baseline Extension: Arducam Camarray HAT implements Variable Baseline Extension to achieve synchronized stereo vision across multiple cameras.
IMAGE SENSOR IMX708
Still Resolution 11.9 Megapixels
Common Video Modes 1536x864@60fps , 2304x1296 @28fps, 4608x2592@7fps
Sensor Resolution 4608 x 2592 pixels
Sensor image area 6.45 x 3.63mm (7.4mm diagonal)
Pixel Size 1.4μm × 1.4μm
Optical Size 1/2.43"
Output/CSI-2 Speed  x1 CSI-2 2-lane Output Port/1.0 Gbps/Lane
Output Format  RAW10
ISP Support  Supported by Raspberry Pi
Aggregate mode  1/4 Spelling Combine
External Trigger Not Support
Camera Interface 2-lane MIPI CSI-2
FOCUS TYPE Autofocus
F.NO F2.2
Field of View(FOV) 120°(D)x100°(H)x72°(V)
Lens Mount Stock Lens
Focus Distance 10cm~infinity
Working Current Max 700mA
Camera Board Size 24×25 mm
Camarray Hat Size 65 x 55mm
  • 4 x IMX708 Autofocus Camera Module
  • 1 x Arducam Camarray HAT
  • 4 x 15cm 22pin Camera Cable
  • 1 x 30cm 22-22pin Camera Cable
  • 1 x 30cm 15-22pin Camera Cable
  • 1 x 7cm 15-22pin Camera Cable
  • 1 x Screw Pack
  • The four-channel camera adopts the 2×2 synthesis method. The images of cameras 0 and 1 are completely synchronized, the images of cameras 2 and 3 are completely synchronized, and the images of cameras 2/3 are one frame behind the images of cameras 0/1.
  • The resolution of the synthesized image remains unchanged, but the frame rate is halved. This Kit Combines four cameras into one frame, each camera with a max resolution of 2304(H)x1296(V).
  • If any camera fails, the composite image can still be output, with the corresponding area of the failed camera being black.
  • The four-channel camera is a customized model, requiring HAT to provide a clock. It cannot be removed and is directly connected to the Raspberry Pi.
  • The driver of the kit is mainly developed based on the Raspberry Pi official board, and there is no guarantee that the third-party board can be used (Due to the different allocation of hardware resources, it may not be compatible)
  • This camera kit adopts a special autofocus control method, where the autofocus of all cameras is controlled by the camera located at the RX0 interface position (which is labeled with RX0 on the MIPI-CSI interface of the Arducam CamArray HAT). By moving the camera(at the RX0 position), autofocus can be achieved for a single camera, and autofocus will also be simultaneously performed for the remaining cameras.
    Raspberry Pi 5
