12MP IMX708 Autofocus Camera Module 3 with HDR Mode and PDAF Function for Raspberry Pi
12MP IMX708 Autofocus Camera Module 3 Wide with HDR Mode and PDAF Function for Raspberry Pi
Arducam LAN Cable Extension Kit for Camera Module on NVIDIA Jetson Orin Nano/Orin NX
U6279
  • Plug-and-play cable extension kit
  • Up to 10-meter cable extension
  • No additional software configure needed
  • Compatible with official NVIDIA Jetson Board and many Arducam cameras
$49.99
This LAN extension cable kit is a solution for connecting the camera module to the processor over long distances. Replacing the CSI cable (Camera Serial Interface) with a LAN/Ethernet cable extends the length of the available cable and places the camera module up to 10 meters away from the NVIDIA Jetson board. No additional drivers or software are required to control your camera module from a distance.
The extension kit consists of two parts: the transmitter board (Tx board), which is used to connect the camera module, and the receiver board (Rx board), which is securely fastened to the processor via GPIO pins. Below is the list of camera modules supported by the kit:
Supported Camera Modules Video Modes
Product Series for NVIDIA Jetson Orin Nano/Orin NX*
Camera Module V1 (OV5647) Not supported
Camera Module V2 (IMX219) 3280x2464@21fps
3280x1848@28fps
1920x1080@30fps
1640x1232@30fps
1280x720@60fps
HQ Camera (IMX477) 4056x3040@10fps
2028x1520@30fps
2028x1080@30fps
Camera Module V3 (IMX708) Not supported
Arducam IMX519 Camera 4656x3496@9fps
3840x2160@17fps
1920x1080@60fps
1280x720@120fps
Arducam 64MP Camera Not supported
Arducam ToF Camera (B0410) 240x180@30fps
* Tested on Jetson Orin NX/Orin Nano (L4t36.3.0/Jetpack6.0). When used on the Orin Nano/Orin NX, a longer 15-22 pin FPC is needed.
  • UAV/Drones/FPV camera
  • Machine Vision
  • Robotics
  • Face Recognition
  • Defect Detection
Operation Steps
Operation Steps Assembly Instructions
1 Plug the Rx board into the Raspberry Pi board;
2 Plug the Tx board into the Raspberry Pi camera;
3 Connect the Rx and Tx boards with a network cable.
  • 1 x The Rx board
  • 1 x Tx board
  • 1 x 1-meter LAN cable
  • 2 x 8cm ribbon flex cables for MIPI CSI-2 Transmission
  • 2 x 7.3cm 15-22pin FPC Cable
  • 1 x pack of mounting screws
  • No SBC board/Camera Board is included in the package
