Arducam 12MP 477P Pan Tilt Zoom(PTZ) Camera for Raspberry Pi 4/3B+/3 and for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX, IR-Cut Switchable Camera
Arducam 12MP*2 Synchronized Stereo Camera Bundle Kit for Raspberry Pi and Pi zero, Two 12.3MP 477P Camera Modules with CS Lens and Camarray Stereo Camera HAT
Arducam 12MP 477P Autofocus High Quality Camera for Raspberry Pi
B0272
  • Motorized Focus: Programmable autofocus, software to control
  • Simpliy Control: Python- OpenCV sofrware, also support using “up” and “down” to adjust the focus
  • Native to Raspberry Pi: No need to install additional driver, just make some configuration
  • Check Jetson Nano version SKU: B0273
was $89.99 Special Price $69.99
This Arducam High Quality motorized focus camera module integrates a motor that could be controlled by software for a smarter focus, and you will no longer focus the camera by screwing the lens with your bare hands. Instead, keyboard keys or OpenCV can be used to remotely control the focusing process of your HQ camera. To learn more about autofocus with Raspberry Pi camera modules, we recommend you read Raspberry Pi Camera Autofocus: The Complete Guide.
  • DSLR Camera Control
  • Remote Viewing Camera
  • Time-lapse Machine
  • Security System
  • Smart Video Doorbell
  • Face Recognition
  • Instant (Polaroid-Style) Camera, etc.
Video Modes 2028 × 1080p50, 2028 × 1520p40 and 1332 × 990p120
Pixel Size 1.55 µm x 1.55 µm
Optical Size 1/2.3"
Focus Type Motorized
Focal Length 3.9mm
Field of View(FOV) 75°(H)
MOD 0.3
Back Focal Length 4.49mm
Lens Dimension  Φ14×18.67mm
Electrical & Mechanical
Camera Board Size 38 × 38mm
Hole Pitch Compatible with 29mm, 30mm, 34mm
Power requirement with motorized motor: 3.3V/500mA max
without motorized motor: 3.3V/300mA max
Peaking Current 300mA
  • 1 × Arducam 12MP Motorized Focus High Quality Camera for Raspberry Pi with lens
  • 1 × 300mm 15pin-22pin flex ribbon cable for Raspberry Pi normal variants (Model As and Bs)
  • 1 × 300mm 22pin-22pin flex ribbon cable for Raspberry Pi Zero and Compute Module
  • Our camera module support 4-lane in hardware, but the 4-lane camera driver requires extra customization. Here is why:
    1. Standard Raspberry Pi and Jetson Nano/Xavier NX can’t physically support a 4-lane connection (both of them only have 2-lane CSI connectors). Only the Raspberry Pi Compute Module and some 3rd party Jetson Carrier Boards come with 4-lane hardware support. Therefore, it’s not a general need.
    2. Extra works, specifically camera drivers, are required for a 4-lane connection other than the 4-lane physical connector. And the drivers are limited by the performances of the platform itself. For example, 4-lane can’t unlock 4k video on Raspberry Pi because the VideoCore does not currently support it. Jetson Nano is also to some extent limited because of the encoding capabilities. You need to make sure you really need it.
  • It is not recommended to replace the default lens on the camera module, contact us first if needed
3D drawing.step
3D drawing_Case.step
12MP IMX477 Motorized Focus Camera Module
Introduction This Arducam IMX477 High Quality motorized focus camera module integrates a motor that could be controlled by software for a smarter focus, and you will no longer focus the camera by screwing the lens with your bare hands.So how has software focus control made it more convenient? Here is an idea: Arducam provides you […]
  • Quick Start Guide - 12MP Motorized Focus Camera Module
  • Blog
    raspberry pi high quality camera autofocus blog thumbnail
    Software-Controlled Focus on 12MP IMX477 High Quality Camera: Keyboard Focus Control or Even Autofocus
    With a software-controlled focus motor in the lens assembly, Arducam uses OpenCV to automate the focus process on a 12MP IMX477 High Quality Camera on the Raspberry Pi. This is how that looks like. This is specifically about the autofocus HQ camera. If you are interested in the general autofocus topic on Raspberry Pi, we […]
    GitHub
    ArduCAM/RaspberryPi
