Arducam 12MP 477P Pan Tilt Zoom(PTZ) Camera for Raspberry Pi 4/3B+/3 and for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX, IR-Cut Switchable Camera
Arducam 12MP*2 Synchronized Stereo Camera Bundle Kit for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX, Two 12.3MP 477P Camera Modules with CS Lens and Camarray Stereo Camera HAT
Arducam 12MP 477P Motorized Focus High Quality Camera for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
B0273
Check Raspberry Pi version SKU: B0272
The same 12MP High Quality Camera, but with smarter focus control – No more hand touching.
  • The intuitive focus control: Fine-tune the focus with keyboard arrow keys.
  • The automated focus control: Autofocus with OpenCV examples
Focus motor controlled via camera I2C. No hardware modification required.
Note: For the new version(R32 4.4), please refer to the following link: https://github.com/ArduCAM/MIPI_Camera/releases/tag/v0.0.2
was $79.99 Special Price $69.99
This Arducam High Quality motorized focus camera module integrates a motor that could be controlled by software for a smarter focus, and you will no longer focus the camera by screwing the lens with your bare hands. Instead, keyboard keys or OpenCV can be used to remotely control the focusing process of your HQ camera. Other than its motorized focus, it offers the same picture quality and camera controls as the Raspberry Pi High Quality camera. However, the Arducam High Quality Camera Modules do not require any hardware modifications to work with the and Jetson Board.
Note: This camera is released for the official NVIDIA® Jetson™ Developer Kit, and it does not guarantee to support other third-party boards.
★KERNEL CAMERA DRIVER USED
Pixel Size 1.55 µm x 1.55 µm
Optical Size 1/2.3"
Focus Type Motorized
Focal Length 3.9mm
Field of View(FOV) 75°(H)
MOD 0.3
Back Focal Length 4.49mm
Lens Dimension  Φ14×18.67mm
Electrical & Mechanical
Camera Board Size 38 × 38mm
Hole Pitch Compatible with 29mm, 30mm, 34mm
Power requirement with motorized motor: 3.3V/500mA max
without motorized motor: 3.3V/300mA max
Peaking Current 300mA
  • 1 × Arducam 12MP Motorized Focus High Quality Camera for Jetson Board with lens
  • 1 × 300mm 15pin-22pin flex ribbon cable
  • 1 × 300mm 22pin-22pin flex ribbon cable
IMX477 – Motorized Focus Camera
Introduction This Arducam IMX477 High Quality motorized focus camera module integrates a motor that could be controlled by software for a smarter focus, and you will no longer focus the camera by screwing the lens with your bare hands.So how has software focus control made it more convenient? Here is an idea: Arducam provides you […]
3D drawing.step
3D drawing_Case.step
raspberry pi high quality camera autofocus blog thumbnail
Software-Controlled Focus on 12MP IMX477 High Quality Camera: Keyboard Focus Control or Even Autofocus
With a software-controlled focus motor in the lens assembly, Arducam uses OpenCV to automate the focus process on a 12MP IMX477 High Quality Camera on the Raspberry Pi. This is how that looks like. This is specifically about the autofocus HQ camera. If you are interested in the general autofocus topic on Raspberry Pi, we […]
