The Arducam 12.3MP HQ Fisheye MIPI Camera Module brings ultra-wide, high-resolution imaging to your Raspberry Pi projects. Powered by the high-performance 12.3-megapixel sensor (4056x3040), it captures rich visual details across a massive 220-degree field of view. Its extreme fisheye perspective eliminates blind spots, making it ideal for comprehensive spatial monitoring. Utilizing the high-speed MIPI CSI-2 interface, this camera integrates seamlessly into the Raspberry Pi platform and is fully supported by Arducam’s OEM customization services for tailored optical and hardware setups.
360° & Panoramic Surveillance: Ideal for whole-room monitoring, smart security domes, and wide-area security coverage.
Robotics & Obstacle Avoidance: Provides wide spatial awareness and optical flow data for autonomous mobile robots and drones.
VR & Immersive Media: Perfect for stitching together virtual reality content, hemispherical capturing, and interactive displays.
Sky & Meteorological Cameras: Captures full-sky imagery for cloud coverage tracking, solar modeling, and astronomy projects.
[12MP HQ Clarity] Equipped with a premium 12.3-megapixel sensor capturing 4056x3040 resolution, ensuring exceptional image clarity and dynamic range for high-density visual analysis.
[220° Ultra-Wide Fisheye Lens] Features a specialized 220-degree field-of-view M8 lens that captures full hemispherical scenes, drastically reducing the number of cameras needed for wide coverage.
[MIPI CSI-2 Connectivity] Transmits raw, high-throughput image data directly to the Raspberry Pi CPU via the MIPI CSI-2 bus, guaranteeing minimal latency and low processing overhead.
[Seamless Raspberry Pi Setup] Designed specifically for the Raspberry Pi ecosystem, plugging straight into standard CSI ribbon connectors for quick, driver-supported deployment out of the box.
[Tailored OEM Customization] Supports broad custom tweaks for volume integrators, including interchangeable lens options, optical IR-cut filters, custom flexible cable lengths, and board redesigns."
[Tailored OEM Customization] Supports broad custom tweaks for volume integrators, including interchangeable M8 lens options, optical IR-cut filters, custom flexible cable lengths, and board redesigns.
1 x Arducam 12.3MP IMX477F 220° FIsheye MIPI Camera Module for Raspberry Pi
1 x 15cm 15-22pin FFC Cable
1 x 15cm 22-22pin FFC Cable
This module supports customized resolution, frame rate, and ROI, etc.
This module supports a minimum exposure time of 100µs under the current UVC protocol. For even lower exposure times, please contact Arducam for customization.
