4mm Manual Focus USB Camera with 1/2.7
4mm Manual Focus USB Camera with 1/2.7" AR0230 Image Sensor, Full HD 1080P HDR Webcam with CCTV Video Lens for Android, Linux, Windows, and Mac OS-Arducam
Arducam 1080P USB Webcam, 2.8-12mm Varifocal Lens USB Camera with CMOS Sony IMX291 Image Sensor, Microphone and Mini Tripod for Linux, Windows, and Mac OS
Arducam 10MP USB Camera Evaluation Kit - CMOS MT9J001 1/2.3-Inch Monochrome Camera Module with USB2 Camera Shield
EK008
$119.99
The MT9J001 camera module features Aptina’s breakthrough low-noise CMOS imaging technology that achieves near-CCD image quality (based on signal-to-noise ratio and low-light sensitivity) while maintaining the inherent size, cost, and integration advantages of CMOS. It incorporates the monochrome version of the MT9J001 sensor on board.
1/2.3" 10MP (3856 x 2764) CMOS monochrome rolling shutter with global reset release camera module MT9J001 .
World-Class 1.67μm Pixel Sensitivity, Produced on Aptina’s world-class 1.67μm pixel with Aptina A-Pix technology, this high-resolution, highly sensitive compact sensor is perfect for DSC/DVC designs.
Improved Low Light Performance Equivalent level as CCD sensor to support DSC applications.
Preprocessing Features, including resampling for sub-sampled video and 2D defect correction, provide improved image quality.
  • 1/2.3" optical format
  • Monochrome pattern
  • 10MP 3856 x 2764 MT9J001 sensor
  • 1.67 x 1.67 um Pixel size
  • 0.31V/lux-sec responsivity
  • 65.2dB dynamic range
  • single 3.3V power input
  • Parallel camera interface
  • M12 mount lens
  • Digital video cameras
  • Digital still cameras
  • Industrial camera
  • Medical camera
  • Microscopy camera
Documentation:
MT9J001/MT9J003 DVP Camera with USB2.0 Camera Shield Rev.E
1.Introduction USB2.0 camera shield Rev.E is that it supports MIPI interface sensors without any MIPI adapter board. It has an onboard 16MByte hardware frame buffer and has overcome the bandwidth and dropping frames issue when using the software frame buffer scheme. In addition, the onboard frame buffer supports synchronized multiple cameras taking images exactly at […]
Posts not found
Arducam USB Camera Shields
Arducam MT9J003 Camera Evaluation Kit - Application Note
Arducam Camera Evaluation Kit - SDK&API
GitHub:
ArduCAM_USB_Camera_Shield
Packing List:
  • 1pcs Arducam CMOS MT9J001 1/2.3-Inch 10MP Monochrome Camera Module
  • 1 pcs USB2 Cable
