B0354 is a new member of Arducam's USB camera family. It's a complete bundle, based on the 2MP 1/2.8″ Sony IMX291 image sensor, UVC compliant, USB 2.0 camera. No longer be anxious about installing the driver! The native UVC drivers of Windows, Linux, and Mac shall be compatible with this camera so that it does not require extra drivers to be installed.
- Sensor: 1/2.8” IMX291
- Resolution: 1947(H) x 1109(V)
- Data Format: MJPG/YUY2/H.264
- Frame Rate: MJPG 30fps@1080P/720P/640 x 480/320 x 240; 30fps@1080P/720P/1024 x 768; YUY2 30fps@640 x 480/320 x 240. H.264 30@1080P/720P/640 x 480.
-Field of View (FOV): 86°-28°
- Lens Mount: CS
- Focal Length: 2.8-12mm
- Auto Controlled Features: Saturation, Contrast, Acutance, White balance, Exposure.
- Audio: Single microphone
- System Compatibility: Windows, Linux, and Mac with UVC
Power
-Power Supply: USB powered 5V
-Working Current: MAX 300mA
Physical
-Operating Temp.: -4°F~158°F (-20°C~+70°C).
-Dimension: 50mmx50mmx80mm
-Cable Length: default 6.56ft (2M)
