This completed USB camera is based on a 1/2.7” 2MP AR0230 image sensor, manual focus, UVC compliant USB 2.0 camera.
Mounted in an aluminum enclosure and assembled with a 4mm focal length CS lens.
A USB2.0 cable and a mini tripod stand are also included, ready to use, just plug and play, no extra drivers are needed.
[HD 1080P Webcam] High-quality USB camera adopted CMOS AR0230 image sensor with max resolution 1920x1080 for sharp image and accurate color reproduction. High frame rate: 1080P@30fps, Compression format: MJPG / YUY2;
[4mm Manual Focus Video Lens] 4mm varifocal lens USB camera with IR-cut filter@650nm provides a field of view 75°(H). The minimum focusing distance is 15mm, which could capture every tiny detail for true and undistorted color images.
[HDR & WDR] The high dynamic range up to 96dB, its ability to capture both continuous video and decent images in strong/weak light conditions.
[Plug & Play] Ready to use, assembled with an aluminum case and a mini tripod, you can simply put this completed camera on your desk or any flat surface. UVC-compliant, just connect the camera to a PC computer, laptop, or Raspberry Pi with the USB cable without extra drivers to be installed.
[Applications] Highly recommended for the video surveillance system, live streaming, video conference, dashcam, and other video vision applications need high frame rates with high resolution.
Sensor: 1/2.7” AR0230
Resolution: 1928(H) x 1088(V)
Data Format: MJPG/YUY2
Dynamic Range: Up to 96dB
Frame Rate: MJPG 30fps@1080P/720P/1280 x 1024/800 x 600/640 x 480; YUY2 5fps@1080P/720P; 20fps@800 x 600/960 x 540; 30fps@640 x 480.
Field of View (FOV): 75°(H)
Lens Mount: CS
Focal Length: 4mm
Auto Controlled Features: Saturation, Contrast, Acutance, White balance, Exposure.
System Compatibility: Windows, Linux, Android, and Mac with UVC
Power
Power Supply: USB powered 5V
Working Current: MAX 300mA
Physical
Operating Temp.: -4°F~158°F (-20°C~+70°C).
Dimension: 50mmx50mmx65mm
Cable Length: default 6.56ft (2M)
