Arducam 1080P Low Light Low Distortion USB Camera Module with Microphone
5MP UVC Camera Module with Wide Angle M12 Lens for Windows, Linux, Android, and Mac OS
5MP UVC Camera Module with Wide Angle M12 Lens and Metal Housing for Windows, Linux, Android, and Mac OS
B0454C
  • [Plug-and-Play] UVC-compliant, No additional driver is needed.
  • [Ultra HD] Based on performance 5MP color image sensor.
  • [Wide-Angle] Armed with a wide angle low distortion M12 Lens.
  • [Onboard ISP] Integrated hardware ISP. Support auto exposure, auto white balance, etc.
  • [Upgraded item available now] NEW ITEM B045401C with HDR and AI Resolution enhanced.
As low as $42.99
It is a fully UVC-compliant plug-and-play solution with a robust metal housing that works seamlessly on Windows, Linux, Android, and macOS with no driver installation required. Built on a high-performance 5MP color image sensor, it delivers sharp Ultra HD visuals suitable for a wide range of vision applications. The module comes equipped with a wide-angle, low-distortion M12 lens for accurate and extended scene coverage, while the onboard hardware ISP ensures consistent image quality with auto exposure, auto white balance, and other essential controls handled directly on the device.
An upgraded version B045401C is also available, featuring enhanced HDR imaging and AI-optimized resolutions for more demanding computer-vision workflows.
  • Live streaming
  • Videoconference
  • Monitoring 3D printer
  • Dashcam
  • Plug-and-Play UVC Compatibility It is fully UVC-compliant, enabling seamless plug-and-play operation on Windows, Linux, Android, and macOS without any driver installation. It integrates easily into existing systems for rapid deployment.
  • Low-Distortion Wide-Angle M12 Lens The integrated M12 lens offers an wide horizontal field of view with low optical distortion, ensuring accurate scene capture for robotics, smart terminals, people detection, and other spatial-awareness applications.
  • Onboard Hardware ISP Featuring a built-in image signal processor, the camera delivers consistent, high-quality output with hardware-level enhancements.
  • Upgraded Variant with HDR and AI Resolutions A new enhanced version of the module is available, adding High Dynamic Range (HDR) for superior performance in challenging lighting and AI-optimized YUV resolutions for edge inference.
  • Metal Case Housed in a robust metal enclosure, the camera benefits from excellent heat dissipation and structural integrity. The metal case not only enhances durability but also helps maintain stable performance during extended use or in demanding environments.
General Sepcs B045401C B0454C-1
Still Resolution 5MP 5MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/2.8'' 1/4"
Pixel Size 2 µm x 2 µm 1.4 µm x 1.4 µm
Sensor Active Area 2592(H)x1944(V) 2592(H)x1944(V)
Frame Rate MJPG: 2592*1944@30fps; 2048x1536@30fps;
1920x1080@30fps; 1600x1200@30fps;
1280x960@30fps; 1280x720@30fps;
1024x768@30fps; 800x600@30fps;
640x360@30fps; 640x480@30fps;
MJPG: 2592x1944@15fps, 2048x1536@15fps;
1600x1200@15fps, 1920x1080@30fps;
1280x960@30fps, 1280x720@30fps;
1024x768@30fps, 800x600@30fps;
640x360@30fps, 640x480@30fps;
YUY2: 2592x1944@2fps, 2048x1536@2fps;
1920x1080@5fps, [email protected];
[email protected], 1280x720@10fps;
1024x768@10fps, 800x600@20fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
Focus Type Fixed Focus Fixed Focus
FOV 101°(D)×88°(H)×60°(V) 110°(D)x95°(H)x76°(V)
Lens Mount M12-S M12-S
F.NO F2.8±5% F2.5±10%
E.F.L 2.7mm 2.1mm
Default Focus Range 300cm-∞ 300cm-∞
Distortion <-1.0% <20%
Operating Voltage DC 5V +/- 5% DC 5V +/- 5%
Power Consumption Typical: 1.043w Typical: 0.818W
Camera Board Size 32mm x 32mm x 1.6mm 38mm x 38mm x 1.6mm
HDR Support Yes NO
Enclosure with Metal Enclosure with Metal Enclosure
Supported OS Windows, Linux, Android Windows, Linux, Android
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Lowlight Compensation, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
  • 1 x Arducam 5MP Wide Angle USB Camera Module
  • 1 x USB Cable (1m)
  • 1 x Quick start guide
  • No platform board (Raspberry Pi/Nvidia Jetson Nano/NX board) is included in the package
