Arducam 8 MP Sony IMX219 camera module with CS lens 2718 for Raspberry Pi
Arducam NOIR 8 MP Sony IMX219 camera module with M12 lens LS1820 for Raspberry Pi 4/3B+/3
Arducam 8MP Sony IMX219 camera module with Motorized IR cut filter M12 mount LS1820 Lens for Raspberry Pi 4/3B+/3
B0154
  • Replaceable Lens: You can change other M12 lens for this camera
  • IR Sensitivity: Motorized IR-CUT Fliter, which support both daylight and night version
  • System Compatibility: Support the lastest Raspberry Pi OS and libcamera apps
was $64.99 Special Price $40.00
Arducam team just released an 8MP Raspberry Pi compatible camera based on the Sony IMX219 image sensor. It’s capable of 3280 x 2464 pixel static images, and also supports video. It attaches to Pi by the dedicated standard CSi interface.
This camera has a Motorized IR-CUT M12 lens which can switch the daylight/night mode automaticly. It can be widely used in a range of low light conditions. It is supplementary for Raspberry Pi official camera in order to fulfill the demands for different lens mount, the field of view (FOV) and depth of the field (DOF) as well as the motorized IR cut filter for both daylight and night vision.
There are a wide range of lens options which you can choose from us
  • Cellular phones, PDAs, Toys
  • Recording slow motion
  • Wildlife photograph
  • Home Security Supervise
  • Machine vision, etc.
Image Sensor IMX219
Still Resolution 8 Megapixels
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
IR Sensitivity Switch the IR cut filter on/off automatically
Focal Length 1.8mm
F.NO F2.4
Field of View(FOV) 100°(H)
Electrical & Mechanical
Camera Board size 36 x 36 mm
Peaking Current 300mA
  • 1 x 8 Megapixels IMX219 Sensor Camera Module with Motorized IR-cut lens
  • 1 x 15cm 15-15pin FPC cable
  • 1 x 15cm 15-22pin FPC cable
Raspberry Pi 5 √ √
8MP IMX219 Motorized IR-CUT Camera Module
Introduction Arducam 8MP IMX219 Motorized IR-CUT Camera Module is designed for both daylight and night vision photography. The motorized IR cut filter can be switched ON/OFF automatically according to the light environment. The camera in this serial is fully supported by all the Raspberry Pi board versions including Pi 4/3B+/3. It can be widely used […]
3D drawing.step
noir_rpi_camera_blog_thumbnail
ArduCAM NOIR Raspberry Pi camera with Motorized IR Cut Filter
Background Raspberry pi camera has both color version pi camera board and NoIR version pi camera board. So let’s take a look at the difference between these two types of cameras. The color version pi camera has 650nm IR cut filter on top of the sensor, so it can only sensitive to visible light like […]
Selection Guide
Edit
