Arducam team just released an 8MP Raspberry Pi compatible camera based on the Sony IMX219 image sensor. It’s capable of 3280 x 2464 pixel static images, and also supports video. It attaches to Pi by the dedicated standard CSI interface.
This camera has a NoIR M12 lens which can be applied under low light conditions. It is supplementary for Raspberry Pi's official camera in order to fulfill the demands for different lens mounts, the field of view (FOV) and depth of the field (DOF), as well as the motorized IR-cut filter for both daylight and night vision.
There is a wide range of lens options that you can choose from us:
| Image Sensor | IMX219 |
| Still Resolution | 8 Megapixels |
| Video Modes | 1080p47, 1640 × 1232p41 and 640 × 480p206 |
| Sensor Resolution | 3280 × 2464 pixels |
| Sensor image area | 3.68 x 2.76 mm (4.6 mm diagonal) |
| Pixel Size | 1.12 µm x 1.12 µm |
| Optical Size | 1/4" |
| IR Sensitivity | without IR-cut filter, sensitive to IR light |
| Focus Type | Manual Focus |
| Focal Length | 1.8mm |
| F.NO | F2.4 |
| Field of View(FOV) | 100°(H) |
| Lens Mount | M12 Mount |
| Camera Board size | 36 x 36 mm |
| Peaking Current | 300mA |
Introduction Arducam team just released an 8MP Raspberry Pi compatible camera based on the same Sony IMX219 image sensor. It’s capable of 3280 x 2464 pixel static images, and also supports 1080p30, 720p60 and 640x480p90 video. It attaches to Pi by the dedicated standard CSi interface. It is supplementary for Raspberry Pi official camera in […]
Introduction ArduCAM team just released a 8MP Raspberry Pi compatible camera based on the same Sony IMX219 image sensor. It’s capable of 3280 x 2464 pixel static images, and also supports 1080p30, 720p60 and 640x480p90 video. It attaches to Pi by the dedicated standard CSi interface. It is the supplementary for Raspberry Pi offical camera in order […]
