Arducam NOIR 8MP Sony IMX219 camera module with CS lens 2718 for Raspberry Pi 4/3B+/3
Arducam 8MP Sony IMX219 camera module with Motorized IR cut filter M12 mount LS1820 Lens for Raspberry Pi 4/3B+/3
Arducam 8 MP Sony IMX219 camera module with CS lens 2718 for Raspberry Pi
B0102
  • Replaceable Lens: Various CS lens options for this camera
  • IR Sensitivity: Integral IR Filter, visible light only
  • System Compatibility: Support the lastest Raspberry Pi OS and libcamera apps
was $64.99 Special Price $40.00
Arducam team just released an 8MP Raspberry Pi compatible camera based on the same Sony IMX219 image sensor. It’s capable of 3280 x 2464 pixel static images, and also supports video. It attaches to Pi by the dedicated standard CSi interface.
This camera has a CS Lens which allows you to adjust the focus and F.NO manually. It is supplementary for Raspberry Pi official camera in order to fulfill the demands for different lens mount, the field of view (FOV) and depth of the field (DOF) as well as the motorized IR cut filter for both daylight and night vision.
It's OK for you to chosse a different lens.
Please check the link:
http://www.arducam.com/downloads/Lenses/
Image Sensor IMX219
Still Resolution 8 Megapixels
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
Focal Length 4.0mm
F.NO F1.4
Field of View(FOV) 70°(H)
Lens Mount CS Mount
Electrical & Mechanical
Camera Board Size 36 x 36mm
Peaking Current 300mA
  • 1 x 8 Megapixels IMX219 Sensor Camera Module with CS Mount
  • 1 x 15cm 15-15 pin FPC cable
  • 1 x 15cm 15-22 pin FPC cable
Raspberry Pi 5 √ √
8MP IMX219 Standard Camera Modules
Introduction Arducam team just released an 8MP Raspberry Pi compatible camera based on the same Sony IMX219 image sensor. It’s capable of 3280 x 2464 pixel static images, and also supports 1080p30, 720p60 and 640x480p90 video. It attaches to Pi by the dedicated standard CSi interface. It is supplementary for Raspberry Pi official camera in […]
Mechanical Drawing
8mp_sony_imx219_blog_thumbnail
8MP Sony IMX219 Camera for Raspberry Pi
Introduction ArduCAM team just released a 8MP Raspberry Pi compatible camera based on the same Sony IMX219 image sensor. It’s capable of 3280 x 2464 pixel static images, and also supports 1080p30, 720p60 and 640x480p90 video. It attaches to Pi by the dedicated standard CSi interface. It is the supplementary for Raspberry Pi offical camera in order […]
Selection Guide
Edit
You can purchase this item from Arducam distributors.
