Arducam IMX219 Visible Light Fixed Focus Camera Module for Raspberry Pi
Arducam 8MP*4 IMX219 Quadrascopic Camera Bundle Kit for Raspberry Pi, NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam 8MP IMX219 Night Vision Camera Module for Raspberry Pi 4B, 3B+, 3B, 2B, Pi Zero & W (NoIR)
B0395
  • [2-lane/4-lane Support]Adopt MIPI CSI-2 interface, supporting 2lane/4lane output configurations.
  • Great Compatibility: Available for all models of Raspberry Pi 1, 2, 3, and 4B
  • Can be accessed via the MMAL and V4L APIs, and there are many third-party libraries built for it, including the Picamera Python library
  • NOIR: Without IR fliter, sensitive to IR light, which can help you achieve your night/low light project
was $24.99 Special Price $17.99
This IR-sensitive Raspberry Pi camera module uses the Sony IMX219 8-megapixel sensor, which gives you all the specifications offered by the regular V2 camera module, but with one difference: it does not work with IR filters (NoIR = no IR filter.). This means that your photos taken during the day will look very reddish, but it allows you to see normal scenes in the dark through infrared light. The Pi NoIR is very popular among wildlife enthusiasts: with a few infrared LEDs, you can monitor the activities of nocturnal animals in your garden without disturbing them. You can also use it to monitor the health of your green plants at night. You don't need to keep an eye on your plants at all times, just use the camera to record them.
Application
  • Night/Low Light vision
  • Wildlife photograph
  • Home Security
  • Time-lapse
  • Recording slow motion
  • Machine vision, etc.
  • High-Speed Data Interface: Standard 2-lane MIPI CSI-2 interface with configurable 4-lane high-performance mode. Delivers maximum bandwidth for high-resolution sensor data transmission while maintaining compatibility with mainstream embedded platforms.
  • More Than HD: This camera adopts a 1/4” 8MP IMX219 sensor for sharp image
  • Higher Resolution: Max. still resolution is 3280 x 2464 pixels
  • NoIR: It is greatly useful to your various night projects
Image Sensor IMX219
Still Resolution 8 Megapixels
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
IR Sensitivity without IR-cut filter, sensitive to IR light
Focal Length 3.04mm
F.NO F2.0
Lens Type Stock Lens
Electrical & Mechanical
Interface MIPI CSI-2
Data Lanes 2-lane (default), configurable to 4-lane
Camera Board Size 25 × 24mm
Peaking Current 300mA
  • 1pcs camera board with IMX219 NoIR Sensor
  • 1pcs 15-22pin FPC Cable
  • 1pcs 22-22pin FFC Cable
Raspberry Pi 5 √ √
