Arducam IMX219 V3Link Camera Kit for Raspberry Pi
Arducam 8MP IMX219 Night Vision Camera Module for Raspberry Pi 4B, 3B+, 3B, 2B, Pi Zero & W (NoIR)
Arducam IMX219 Visible Light Fixed Focus Camera Module for Raspberry Pi
B0390
  • [2-lane/4-lane Support]Adopt MIPI CSI-2 interface, supporting 2lane/4lane output configurations.
  • Native to Raspberry Pi: No need to install additional driver for this camera
  • Easy to Set-Up: Just simply connect the camera and Raspberry Pi with a FPC cable
  • IR Sensitivity: Integral IR-CUT fliter, keep only visible light
  • Wide Compatibility: Compatible with Raspberry Pi 3/4 and Raspberry Pi zero
was $19.99 Special Price $9.99
No less than the Raspberry Pi official camera V2, this camera module is also equipped with a high-definition IMX219 8MP sensor for shooting HD video and still images. It is excellent in image quality, color fidelity, and low light.
For beginners, this is a very easy camera module to get started; for advanced players, this camera module has more knowledge that you should explore and DIY.
  • Unmanned Aerial Vehicles (UAVs)
  • Building Drones
  • Autonomous Robotic Systems
  • Mobile Medical Imaging
  • Intelligent Video Analytics (IVA)
  • High-Speed Data Interface: Standard 2-lane MIPI CSI-2 interface with configurable 4-lane high-performance mode. Delivers maximum bandwidth for high-resolution sensor data transmission while maintaining compatibility with mainstream embedded platforms.
  • 8MP HD Camera: Designed for Raspberry Pi, based on Sony 8MP IMX219 Sensor.
  • Higher quality: Compared with the official Raspberry Pi Camera v1, not only the resolution is improved, but its image quality, color fidelity, and low light performance are all upgraded by leap.
  • 1080P High resolution: Supports 3280 × 2464 pixel still images, and still captures.
  • Easy to setup: Simply use the 15pin ribbon cable to attach the CSI port on the Raspberry Pi, then make a simple configuration and you are ready to use the camera.
  • Easy to use for beginners, and for advanced gamers, it offers more to explore.
  • Wide Application: Perfect for time-lapse, slow motion, home security applications, monitoring Octoprint 3D Printer, and wildlife camera trap applications.
Image Sensor IMX219
Still Resolution 8 Megapixels
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
Focal Length 3.04mm
F.NO F2.0
Lens Type Stock Lens
Electrical & Mechanical
Interface MIPI CSI-2
Data Lanes 2-lane (default), configurable to 4-lane
Camera Board Size 25 × 24mm
Peaking Current 300mA
  • 1× Arducam IMX219 Camera Module
  • 1× 15cm 22-22pin FFC Cable
  • 1× 15cm 15-22pin FPC Cable
Raspberry Pi 5 √ √
Documentations
