Arducam 12MP*4 477P Quadrascopic Camera Bundle Kit for Raspberry Pi, NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
64MP Autofocus Synchronized Quad-Camera Kit for Raspberry Pi
Arducam 8MP*4 IMX219 Quadrascopic Camera Bundle Kit for Raspberry Pi, NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
B0396
  • Four in One: Combine four cameras into one frame, each camera with a max resolution of 1640(H)x1232(V)
  • Wide Compatibility: Supports multi-platform multi-camera solutions such as Raspberry Pi, Jetson Board and many more
  • Native to Raspberry Pi and Jetson: No need to install additional driver
  • More Applications: Synchronized video streams with Raspberry Pi could be used for many use-cases (e.g., stitching, 3D sensing, tracking, …)
  • We have enabled VR (Virtual Reality), AR(Augmented Reality), and other applications like SLAM (Simultaneous Localization and Mapping)
  • For NVIDIA JetsonL4t 35.x Jetpack5.x and above versions , you will need the latest CamArray Kit firmware (no earlier than the 2023.02.03 version) to access it.(otherwise you can only use them on previous JetPack versions).
$139.99
This Arducam quadrascopic camera bundle incorporates four 8MP IMX219 cameras, and the cutting-edge MIPI stereo camera breakthrough from Arducam – The Arducam Camarray HAT.
As the upgraded version of Arducam Synched Stereo Camarray HAT, this Camarray further pushes the multi-camera limits and doubles the interfacing capabilities to allow 4 synchronized MIPI camera modules to be interfaced to a single MIPI CSI-2 slot on prevailing single-board computers like Raspberry Pi, Jetson Board.
  • Variable Baseline Extension: Compared to the fixed stereo camera module version, this camera bundle has higher flexibility.
  • ● Four in One: Combine four cameras into one frame, each with a max resolution of 1/4(820(H)x616(V)); the maximum output you can get: 3280 x 2464 for still images and 1920x1080 for video. Please note the frame rate for video and still images will drop to half the frame rate you would normally get with a single camera
  • Wide compatibility: Compatible with the latest Raspberry Pi camera software (libcamera) and uses the official Pi camera tuning algorithm.
  • It also supports multi-platform multi-camera solutions such as Raspberry Pi, Jetson Board, and many more.
  • Multiple camera processing technologies have enabled VR (Virtual Reality), AR(Augmented Reality), and other applications like SLAM (Simultaneous Localization and Mapping).
  • Applications: Synchronized video streams with Raspberry Pi could be used for many use-cases (e.g., stitching, 3D sensing, tracking, …) instead of investing in an expensive video multiplexer hardware.
Specfications
Support Platform Raspberry Pi/Nvidia Jetson
Output/CSI-2 Speed x1 CSI-2 2-lane Output Port/1.0 Gbps/Lane
Output Format RAW8/RAW10
ISP Support Supported on Raspberry Pi
External Trigger Not Support
Aggregate mode 1/4 Spelling Combine
Frame Rate(On Raspberry Pi) 103fps@640x480,20fps@1640x1232,23fps@1920x1080,10fps@3280x2464
Frame Rates(On NVIDIA Jetson)* L4t 32.x: [email protected], 1080p@15, 720p@30fps
L4t 35.x:3280×[email protected], 3280×1848@14fps, 1920×1080@15fps, 1640×1232@15fps, 1280×720@30fps
Sony IMX219
Pixel Size 1.12 μm x 1.12 μm
Active Array Size 3280 x 2464
Optical Format 1/4”
Camera Interface 2-lane MIPI CSI-2
IR Sensitive Integral IR Cut filter, Visible Light Only
Camera Board Size 24mm x 25mm
Camarray Hat Size 65mm x 55 mm
Default Lens Mount Stock Lens
Effective Focal Length 3.04mm
FOV on 1/4” RPi Camera 62.2° (H), 48.8(V)
*:JetPack4.6/L4T32.6.1 on NVIDIA Jetson Board
Packing List
  • 4 × IMX219 Camera Module
  • 1 × Arducam Camarray HAT
  • 4 × 15cm 22-22pin Camera FPC Cable
  • 1 × 30cm 15-22pin Camera FPC Cable
  • 1 × 30cm 22-22pin Camera FPC Cable
  • 1 × 7cm 15-22pin Camera FPC Cable
  • 1 × Screw Pack
1. The four-channel camera adopts the 2×2 synthesis method. The images of cameras 0 and 1 are completely synchronized, the images of cameras 2 and 3 are completely synchronized, and the images of cameras 2/3 are one frame behind the images of cameras 0/1.
2. The resolution of the synthesized image remains unchanged, but the frame rate is halved.
3. If any camera fails, the composite image can still be output, with the corresponding area of the failed camera being black.
4. Official Commands and ISP are supported on Raspberry Pi Platfomrs.
5. The four-channel camera is a customized model, requiring HAT to provide a clock. It cannot be removed and is directly connected to the Raspberry Pi.
6. The driver of the kit is mainly developed based on the Raspberry Pi/ Nvidia Jeston official board, and there is no guarantee that the third-party board can be used (Due to the different allocation of hardware resources, it may not be compatible)
7. Due to the hardware limitations of the NVIDIA Jetson platform, this product does not support ISP functionality. If a pre-tuned ISP solution is required, please refer to Arducam xISP series or Arducam TrueSight Series
Camarray – Arducam 8MP Synchronized Quad Camera Bundle Kit
Introduction This Arducam quadrascopic camera bundle incorporates four 8MP IMX219 cameras and the cutting-edge MIPI stereo camera breakthrough from Arducam – the Arducam Camarray HAT. As the upgraded version of the Arducam Synched Stereo Camera HAT, the Camarray further pushes the multi-camera limits and doubles the interfacing capabilities to allow 4 synchronized MIPI camera modules […]
