8MP Autofocus USB Camera Module with Single Microphone with Metal Housing for Windows, Linux, Android, and Mac OS , A179
16MP Autofocus USB Camera with Microphone, 1/2.8
16MP Autofocus USB Camera with Microphone, 1/2.8" Mini UVC USB2.0 4K Video Webcam, A298
8MP HDR USB Autofocus Camera Module with Metal Housing for Windows, Linux, Android, and Mac OS, A179
B044701C
  • [HDR] Features the High Dynamic Range function.
  • [High Resolution] 8MP HD, Max resolution: 3264*2448
  • [Autofocus] Armed with a 63° (HFOV) Autofocus Lens.
arducam shipping payment 1
$63.99
8MP HDR USB camera module with a robust metal housing, offering high-resolution autofocus imaging (up to 3264×2448) and excellent thermal performance. Compatible with Windows, Linux, Android, and macOS, it supports plug-and-play operation with no additional drivers required. Equipped with a 63° HFOV autofocus lens and HDR capability, it delivers clear, balanced images even in challenging lighting conditions—ideal for a wide range of applications.
  • Robotics
  • Precision Agriculture
  • [Plug-and-Play] This camera module offers seamless plug-and-play compatibility with Windows, Linux, Android, and macOS systems. No additional drivers or software installations are necessary—just connect via USB and start capturing high-quality images instantly.
  • [HDR] Equipped with High Dynamic Range (HDR) technology, the camera excels at producing well-balanced images in challenging lighting conditions. It effectively manages both bright highlights and deep shadows to deliver clear, detailed visuals across a wide range of environments.
  • [High Resolution] Featuring an 8MP sensor, the camera captures stunning high-definition images with a maximum resolution of 3264×2448 pixels. This ensures sharp and detailed picture quality suitable for applications that demand precision imaging.
  • [Autofocus] The integrated autofocus lens with a 63° horizontal field of view (HFOV) automatically adjusts to varying object distances, guaranteeing consistently sharp focus without manual intervention. This makes it ideal for dynamic scenes or applications requiring frequent refocusing.
  • [Metal Case] Housed in a robust metal enclosure, the camera benefits from excellent heat dissipation and structural integrity. The metal case not only enhances durability but also helps maintain stable performance during extended use or in demanding environments.
General Sepcs B044701C B0447C-1
Still Resolution 8MP 8MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/3.2'' 1/3.2"
Output Format MJPG/YUY2 MJPG/YUYV
Pixel Size 1.4 µm x 1.4 µm 1.4um x 1.4um
Sensor Active Area 3264(H)x2448(V) 3264(H)x2448(V)
640x480@30fps;
3264×2448@30fps, 2592×1944@30fps;
1920×1080@30fps, 1600×1200@30fps;
1280×720, 640×480@30fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
1280×720@10fps, 640×480@30fps;
FOV 75°(D)×61°(H)×50°(V) 63°(H)
F.NO F1.8 F2.0
E.F.L 3.95mm 3.54mm
Operating Voltage 5V 5V
Power Consumption 1.75W 1.5W
HDR Support Yes NO
Enclosure with Metal Enclosure with Metal Enclosure
Supported OS Windows, Linux Windows, Linux
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Lowlight Compensation, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
  • 1 x Arducam 8MP AF Camera Module
  • 1 x USB Cable (1m)
  • 1 x Quick start guide
