8MP HDR USB Autofocus Camera Module with Metal Housing for Windows, Linux, Android, and Mac OS, A179
16MP Autofocus USB Camera with Metal Housing, 1/2.8
16MP Autofocus USB Camera with Metal Housing, 1/2.8" Mini UVC USB2.0 4K Video Webcam, A298
16MP Autofocus USB Camera with Microphone, 1/2.8" Mini UVC USB2.0 4K Video Webcam, A298
B0290-1
  • [High Quality Imaging] 16MP for sharp image with still picture resolution at 4656 x 3496 Max.
  • [Autofocus] Armed with a 60° (HFOV) Autofocus Lens.
  • [Microphone] Equipped with single microphone for audio.
  • [Rich Applications] Can be applied in surveillance systems, 3D Printing, security systems, and so on.
$49.99
A high-performance 16MP USB camera with autofocus and a built-in microphone, delivering crisp still images up to 4656×3496 and smooth 4K video over USB 2.0. Featuring a 1/2.8" sensor and a 60° HFOV autofocus lens, it supports plug-and-play use across Windows, Linux, Android, and macOS with no driver installation required. Ideal for surveillance, 3D printing, security, and other vision-based applications.
  • [High Quality Imaging] Equipped with a 16MP sensor, this camera delivers exceptionally sharp and detailed images with a maximum still resolution of 4656 × 3496 pixels. It is ideal for applications that require high-precision image capture, ensuring clear and vivid visuals every time.
  • [Plug-and-Play] Designed for ease of use, the camera offers full plug-and-play functionality across Windows, Linux, Android, and macOS platforms. No additional drivers or software installations are required — simply connect via USB and start capturing immediately.
  • [Autofocus] Featuring a 60° horizontal field of view (HFOV) autofocus lens, the camera automatically adjusts focus to keep images sharp and clear, even when the subject distance changes. This makes it perfect for dynamic environments where manual focusing is impractical.
  • [Microphone] The built-in single microphone allows for synchronized audio capture, enhancing video recordings with clear sound, suitable for applications such as video conferencing, surveillance, and multimedia creation.
  • Robotics
  • Precision Agriculture
General Sepcs B029002 B0290-1
Still Resolution 16MP 16MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/2.8'' 1/2.8"
Sensor Active Area 4656(H) x 3496(V) 4656(H) x 3496(V)
Frame Rate(MJPG) 4656x3496@10fps, 4000x3000@15fps;
3840x2160@25fps, 3264x2448@25fps;
2592x1944@30fps, 1920x1080@30fps;
1280x720@30fps, 640x480@30fps;
4656x3496@10fps, 3840x2160@10fps;
, 2592x1944@10fps, 1920x1080@30fps;
1280x720@30fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
640×480@20fps, 320x240@30fps;
FOV 75°(D)×61°(H)×50°(V) 60°(H)
F.NO F1.8 /
E.F.L 3.95mm /
Operating Voltage 5V 5V
Power Consumption 1.75W 1W
HDR Support NO NO
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
UVC Camera Module
Manual.pdf
Manual.pdf
3D drawing.STEP
3D drawing.STEP
    • 1 × 16MP IMX298 USB 2.0 camera board
