8MP HDR USB Autofocus Camera Module with Metal Housing for Windows, Linux, Android, and Mac OS , A179
8MP HDR USB Autofocus Camera Module with Metal Housing for Windows, Linux, Android, and Mac OS, A179
8MP Autofocus USB Camera Module with Single Microphone with Metal Housing for Windows, Linux, Android, and Mac OS , A179
B0447C-1
  • [High Resolution] 8MP HD, Max resolution: 3264*2448
  • [Autofocus] Armed with a 63° (HFOV) Autofocus Lens.
  • [Frame Rate] MJPG 30fps@3264 x 2448, 30fps@1080P; YUY2 30fps@640x 480
arducam shipping payment 1
$63.99
8MP USB camera module with built-in autofocus and a single microphone, offering high-resolution imaging (up to 3264×2448) across Windows, Linux, Android, and macOS. With plug-and-play support and no driver required, it delivers smooth video performance at 30fps in both HD and Full HD. Its 63° HFOV autofocus lens ensures sharp focus, making it ideal for applications such as surveillance, 3D printing, and security systems. This is with a metal housing.
  • Robotics
  • Precision Agriculture
  • [Plug-and-Play] Fully UVC-compliant and driver-free, this camera module supports instant plug-and-play functionality across Windows, Linux, Android, and macOS platforms. Simply connect via USB and start capturing without the need for additional software or configuration.
  • [High Resolution] Equipped with an 8MP sensor, the camera delivers high-definition images with a maximum still resolution of 3264×2448, making it ideal for applications that require clear, detailed visuals.
  • [Autofocus] Featuring a built-in 63° horizontal field of view (HFOV) autofocus lens, the module automatically adjusts focus to ensure sharp and accurate imaging, even when object distances change—perfect for dynamic or multi-distance environments.
  • [Frame Rate] Supports smooth video streaming with MJPG compression at up to 30fps for both full 8MP (3264×2448) and 1080P resolutions. Also supports YUY2 format at 30fps for lower resolutions like 640×480, providing flexible options for various bandwidth and performance needs.
  • [Rich Applications] Designed for versatility, this camera module is well-suited for a wide range of use cases including surveillance systems, 3D printing monitoring, security integration, machine vision, and other embedded vision projects.
  • [Metal Case] Housed in a robust metal enclosure, the camera benefits from excellent heat dissipation and structural integrity. The metal case not only enhances durability but also helps maintain stable performance during extended use or in demanding environments.
General Sepcs B044701C B0447C-1
Still Resolution 8MP 8MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/3.2'' 1/3.2"
Output Format MJPG/YUY2 MJPG/YUYV
Pixel Size 1.4 µm x 1.4 µm 1.4um x 1.4um
Sensor Active Area 3264(H)x2448(V) 3264(H)x2448(V)
640x480@30fps;
3264×2448@30fps, 2592×1944@30fps;
1920×1080@30fps, 1600×1200@30fps;
1280×720, 640×480@30fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
1280×720@10fps, 640×480@30fps;
FOV 75°(D)×61°(H)×50°(V) 63°(H)
F.NO F1.8 F2.0
E.F.L 3.95mm 3.54mm
Operating Voltage 5V 5V
Power Consumption 1.75W 1.5W
HDR Support Yes NO
Enclosure with Metal Enclosure with Metal Enclosure
Supported OS Windows, Linux Windows, Linux
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Lowlight Compensation, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
  • 1 x Arducam 8MP AF Camera Module
  • 1 x USB Cable (1m)
  • 1 x Quick start guide
